Everything posted by Combi_NX5
Error rear parking distance control
It's clear that the sensor needs to be replaced again, it's not clear why the sensors are dying in such a short time. Does anyone else have this problem?
When you engage reverse, the following appears. The sensor is nice and clean, with no mechanical damage, and there are no obstacles near the car.
This winter, the same problem with the parking sensors also happened to my Skoda. 2 sensors have already been replaced under warranty. Another one expired a few days ago. Yes, it's been cold here this winter, the air temperature hasn't been above 0⁰ for more than a month, but is that really the reason? Yes, the parking block version was updated to the latest, and the Skoda dealer said that everything should be fine, and we won't see each other again soon. :D I even swapped the sensors myself out of boredom and the error moves to the place where I installed it, since I don't blame the wires and their connections.
annoying message on startup
yes I tested it today, turned off the battery saver, and the unnecessary statement doesn't appear. AA 15.2.653614
Yes, this notification is really annoying, it appears after every cold START. I tried not to press ok, thinking that it would disappear by itself, no it didn't disappear for at least 15 minutes, until I got tired of it. Who should I report this software problem to, it's very annoying to have to poke at the screen every time!
Facelift experience
While my škoda was in the service, they offered me a service exchange car, the new octavia, with a mileage of over a hundred kilometers. In terms of equipment, it wasn't very special, and it didn't provide the driving pleasure that mine does. It was equipped with a 1.5tsi 85kW engine and a 7-speed dsg. As far as I understand, it was a light hybrid, because there was a 48V battery under the right seat. Compared to my pre-facelift, this one seemed to be assembled worse, for example, the door rubbers were poorly installed in some places, and there were also problems with closing the doors, because the door lock stuck. I never closed the door the first time, always the second time I have to slam the door like an old car. The first impression when you get in, you feel at home, basically everything is the same as the pre-facelift Octavia. The difference is that the chrome parts here are matte and there is no more possibility of dazzling the sunbeams. Ambient light was missing at this trim level, although there was a color option in the multimedia settings. The Škoda logo on the steering wheel is also different, but a nice experience compared to mine, this one had a heated steering wheel, which I really appreciated. Next, the heated chairs in this one not only heat the back as it is in my pre-facelift, but also heat the bottom. The multimedia in this one was 10", visually the same big screen as mine pre-facelift, with the same thick black screen edges. Where the shortcut keys on the side have moved to the screen shortcuts. Yes, the multimedia seems faster and more responsive to touches. But the visualization is simple and it's not complicated. If you open Android auto, then the shortcut bar reduces the area on which android auto is displayed, but everything is really simple and understandable, I can quickly adjust everything to my own. Virtual panel copkit, yes it displays to some extent more information, but also there is an iron choice of what and how to display it. To be honest, I prefer to manually configure something. This particular car was equipped with road sign recognition, to be honest I couldn't drive normally at first because it kept affecting the adaptive cruise. Later I found the setting and disabled it. But even when driving outside populated areas, the virtual panel reported the approaching sharp turn or sharp bend and immediately intervened in the cruise control, reducing the speed, the old Octavia is not so smart. What else? I liked the setting, where you can configure the comfort light, when you approach the car, without touching the key or door handles, it turns on the comfort lights. This thing is missing in my old Octavia. Can one be programmed? Also, the new one knows how to lock the car when you move away from the car, the old one only knows how to unlock it when you approach it. The image quality for the rearview camera is better than the old one, does anyone know if it is possible to replace the camera and improve the image quality for the old one? Is it because of the software? It's much better in the dark. What else is left in my memory and missing in my Škoda, probably nothing more. oh yeah, forgot about the lights. So mine is equipped with normal LED lights and + pre-fog LED lights, this one was also without matrixLED and as we already know, there are no more fog lights in facelift models. It seemed to me that the new regular LED dipped beam lights illuminate better than the old Octavia's lights. I often additionally use the fog lights on mine in the dark. Also, the automatic high beam assistant seems to have worked better in the new one, it switched more promptly and does not dazzle others. I'm sorry, I must have thought for a long time, but there are things that I liked, but things like this made me wonder if my next car will be a Škoda. .
MySkoda app is now supporting Octavia iV
On the home page, section 3 - ventilation, you can see the outside air temperature, I did not find it anywhere in the new version.
Condensation in light
this will not be a warranty case
yes, I don't like that the new one shows only one-day trips, I want to see every trip.
12V battery
There are both shorter 20km and longer 80km races. Preheaters are not installed.
12V battery
For a couple of days the air temperature was below -20⁰, in the morning there was no problem with starting even at -26⁰. Now the temperature has rapidly risen to 0⁰. There have been a few cold engine starts, suspiciously slow on the verge of trouble.
12V battery
Has anyone had a 12v battery changed under warranty? Mine tolerated the cold very well, but now there is a problem with starting, I feel that there is a problem, and the START/STOP system stops working. When measuring the battery life with a special battery tester, it shows that the battery needs to be changed.
Door handle looking system
I have many videos of sensors not working, but when the car is in the service, everything works and the warranty repair is refused. Yes, even in good warm weather sometimes the sensors don't work. The problem could be because the key and the phone are in the same pocket.
You won't be the only one with this problem, the same thing happens with my Škoda. I don't know if it's a problem, but it happens when it's winter outside, the temperature is around 0⁰ and it's wet or snowy.
various faults, dealer is replacing pillar trims.
Why they replece the pillar trims? I ask because I have a suspicious noise in it, but the dealer refused to fix it.
- Adaptive cruise control woes.
Infotainment System Restarting endlessly
I want the link too. 😀
Will this not affect the operation of škoda connect, where I can see the location of the car?
I have a feeling that ŠKODA doesn't know about this problem at all. There is probably no time to return to the problems of an "outdated" model. It is easier to draw new models and dream about income and profit. Maybe the staff is so old that they don't understand anything about modern technologies and their operation? I'm sorry, but this is not the service I want to receive. Yes, I am aware that I have not bought a premium segment car, but I'm sorry... 🤦♂️ It is the third day after re-connecting the phone to multimedia. These days I use BT, WIFI connection for AA and this morning the multimedia restart happened in the first minute of the trip. How thin it is for me. 🤯
WOW that's something!😲 I reconnected the phone to multimedia and within two trips no reboot. (I deleted all devices from the list)
The test continues today but there is a problem, unfortunately the reboot also happens with WIFI off and AA connected to USB with wire. Another observation, when AA is connected to WIFI, WAZE will freeze very often. A message to EXIT or WAIT appears in the waze window. Spotify continues to work without problems. I will check if there is an AA update for the phone. Tomorrow I will try to delete the phone from the multimedia memory and connect it again. And test test test 💁🏻♂️
Well, yes, it works! Yesterday I tried the WIFI connection and of course it restarted soon after the start of the trip. Driving to work this morning, no restarts. 💁♂️ I suspect that the restart is more caused by the WIFI connection. BT has been turned on for me even in a wired connection. Yes, try to turn off WIFI on the car side, for example, if WIFI and BT are turned off on my phone, it pairs with multimedia and automatically turns on BT and WIFI on the phone side. So it is better to disable WIFI on the car side.
Voice assistant 'Laura' changing the gender?
Tā kā parasti multimedijā lietoju savas mītnes valsts valodu, tad šodien uzklikšķinot uz multivides uzstādīju angļu valodu, un Lauras vietā man atbildēja Lauris. 🤪
I don't know, but when I bought the car, the manager proudly showed me at the introduction demonstration that CarPlay works wirelessly, and said that the latest Android phones will also work. That's why I even changed my phone to a newer one!
