Derbylad82
Everything posted by Derbylad82
  1. Iv searched the net but not really finding anything the ash level has been same for quite a while I suspect previous owner didn't use the correct oil or something but uses about 1l every 1k which I have been told is normal for the cr engine iv also checked turbo by feeling the shaft through the intake side and can't feel any movement so bit stumped at min
  2. Any advise on sensors to check 1st as with no fault codes I'm bit stumped
  3. My 2014 vrs tdi is constantly regenerating but no fault codes with vagcom I have also run the vag dpf app and shows the dpf lit red when upto temp I'm completely stumped what it could be my soot is slightly high at 76% I have took it for a spirited run for over 30min but still illuminated red but soot is down to around 4g when I pull up. The fan then keeps running and when I get back in a hr or so later soot is above 20g any suggestions would be appreciated???
  4. Went to be remapped and kept going into over boost so mapper said chocked up so needs Mr muscle etc before taking back
  5. Has anyone done the Mr muscle clean on their turbo? If so what's best/ easiest way? Took car to be remapped and kept going into over boost so told sooted up. I Got told today to remove 1st lamba sensor and spray in that way with small piece of hose but never heard it done like this before
  6. Had the car just over a year and when I got the car did the headlight sweep on start up but noticed today its stopped doing it... is their a way to test or reset these please
  7. What in VCDS was meaning as friend who has vcds said nothing he could do
  8. Did you solve this issue as have the same
  9. Pull off from home and had AFS error cornering light pop up on the dash so had it scanned (attached below screenshots) but where do I start been told may just be a bulb but also been told maybe afs control unit any help much appreciated as can't find much online.
  10. Noticed the front vents still blow hot even with climate off so which do you suggest??
  11. Did this and calibrated but don't seem too of resolved it 😪
  12. Scanned my octavia today and had this pop up 328964 Air distribution flap actuator stuck Any suggestions? Is it a easy fix??
  13. Still isn't cold their is no fault codes on vcds and recently had regassed still not cold any suggestions?? Or anything too look for with vcds been suggested by a friend who a mechanic the suction pump on the compressor is a common fault any suggestions?? Awaiting the garage too get back to me still
  14. Sorry couldn't find it and added more info this time
  15. I have a mk3 vrs tdi and when turn air conditioning on it isn't cold their is no fault codes on vcds and recently had regassed still not cold any suggestions?? Or anything too look for with vcds
  16. Almost 2months iv owned it now as did need it till mad heatwave last week so unsure where I stand now with them
  17. Was from a small independent garage
  18. It's holding gas though mate as that was my 1st thought 👍
  19. Iv recently purchased a 2014 octavia mk3 vrs diesel their a/c doesn't blow cold I have scanned with vcds no codes iv had it regassed and vacuum tested and all good so now stumped has anyone else had similar issue??
  20. Remaps not a option as under warranty at min as would of been my 1st choice 👍
  21. Thanks mate@GrimTon
  22. Whats codes please @GrimTon
