Everything posted by Crucian
How do I find out my gearbox code
Hmm spare wheel well sticker has print rubbed off, I suppose a dealer will be able to send me a Build sheet ?
OOh you tease me now, how is said XDS accessed
Cheers, Ill follow this up, Is it possible to fit a limited slip diff ? I find the stability system lacking
As title how can I determine which id no. / gearbox I have fitted (2014 1.4 vrs 7 spd dsg dry unit) any assistance welcomed
Direct replacement calipers for VRS 1.4
I'm having great difficulty sourcing appropriate oem red brake calipers (front and rear) for my 2014 fabia, I can't afford the downtime to remove mine and send for refurbishment. Anyone know of a supplier ?
Brake Fluid Flush
I would agree with @TheClient
Brake Fluid Flush
Possibly uses a CHF (Central hydraulic fluid) if you have a "Wet" dsg, Mine is a "Dry unit" although the videos Ive seen to replace the DSG fluid at the transmission unit not at the brake master cyl. sorry this doesn't help
Wheel refurbishment recommendations
Coincidental post I'm getting my Fabia 17" wheels fully refurbished tomorrow at TWS (The Wheel Specialist) Durham, I have 2 previous vehicle wheels refurbished by them and very pleased each time
Decent Parts catalogue
Managed to track a pipe down, it comes complete with the rubber seal / grommet that has been damaged
Jamesons @Breezy_Pete yes that's exactly it, pity it's out of stock 😕
I know, I've already made a temp (permanent fix) with a section of silicon thick-walled vacuum hose that reliably clears the error But I would like the correct resolution for it
The left hand (D/S) termination of my hose is an O ring unit held in place by a torx screw not a push fit ??
I believe you are correct with the part number but can't find it anywhere and it will still be no good without the correct pipe and push fitting, so Ill look for a correct pipe assembly, LLL parts list it for the beetle and golf
I believe the end of the smaller pipe has had its push fit fitting damaged and is missing and it was relying on grommet 8A to maintain the seal integrity
@Breezy_Pete It goes onto a rear assembly, the attachment point seems fine of it has a tube with a spherical swelling
Hmm, Not much listed for the 1.4 vrs? I'm after the connecting pipe between PCV valve and rear assembly, for some reason its damaged (dealer replaced spark plugs 4 weeks ago !!! I was wondering why error 40501 was showing (Leak in Air intake system), The unseen end has damage (see second image) and is not sealing correctly
@roottoot OOh you tease me, modified ??
Thought I'd selected MK2 !!
OOOh thanks I'll scrutinise now
Anyone know of a good parts catalogue, preferably online for our Fabia MK2s ? I'm looking for PCV / intake hoses, pipes and seals but seem unable to find anything that helps
New owner
Round trip 0f 440 miles returned an av. of 44 MPG (amazing coincidence), very happy with this as the driving conditions were absolutely terrible (Rain) and in total probably 1.5 hrs very slow moving traffic
Over-air update resulted in lost settings
Glad I've got a landrover defender (until the next leak)
Hmmmm, revenue ?
Possibly like bmw you'll have to subscribe for these features going forward ??
