Everything posted by Crucian
Start stop system
Has someone in the past fitted a "stop start defeat device" ? that tricks the ecu into seeing a lower voltage that inhibits stop start ?
Fabia MK2 front door harness AGAIN...
1 wire failure and 4 waiting to happen (as well as those we cant see under the wire insulation) New harness replacement is now £190 🙄
Symptom, Upon locking the car I got a double pulse, from past experience I diagnoses the infamous flexible bit of the harness (pass side front door wasn't locking), poor design (should have used more flexible wires but that would have added £1 to manufacturing costs) I replaced the D/S 3 years ago and bought 2 harnesses at the time so had a spare in the loft, now fitted and all good. I'm going to repair the removed one as a spare
Fabia DQ200 fluids
Both mechatronic and gearbox fluids changed today, old fluids slightly dark but no contaminants 🙂
Rattle going over uneven surfaces
Fitted carriers and OEM pads today and rattle has gone 🙂
- Hi everyone,
I'm assuming there has to be some "gap" so the pads slide and don't seize ?
Will I be able to refurbish the worn carriers, (a bit of weld and refinish) ?
I have a rattle as stated above, we diagnosed it today as front brake pads rattling in the carriers. 2014 Fabia vrs, proving very difficult to source oem correct new carriers in red, I have ordered some from Autodoc and will paint them before we fit them It initially sounded like exhaust contacting chassis or loose subframe fasteners
Fabia DQ200 fluids
Consumables ordered along with drain plugs and appropriate tubing
Fabia DQ200 fluids
Fantastic thanks Comprehensive reply 🙂
Fabia DQ200 fluids
Changing my Fabia DQ200 fluids next month, any hints or tips ?
super717
Keyless start question
Yes fob battery life is greatly shortened (I change mine annually when MOT is done) important to change spare fob battery too and use it approx. once every 3 months (to re sync with the cars rolling codes)
- Fabia VRS Exhuast
Back after a long time away
Welcome back 👍
Air condition sanitisers ?
@StevesTruck Yes pollen filter changed every 2 years
I use an Air con sanitiser bomb when required (odours from the system) What are members go to sanitisers ? I'm trying to find the most effective one/s
Coolant hose problem
No links just images I have on my PC for them and Tracked my last image down where I sourced it 3C0121073AA | search for Škoda spare parts
Workshop Manuals - 2025 edition
@Christophy Great information for the forums thank you. Any chance you have the PDF for the 7 Speed DSG 0AM (2014 Fabia vrs) ?
MOT Time 2014 MK2 1.4 VRS
Next maint milestone I think will be 7 speed dsg cutch pack refresh (Dry) Anyone had this done ?
2013 Fabia brake fluid leak at rear
agree with @Breezy_Pete most likely the wheel cylinder is the issue
