MP74
Everything posted by MP74
  1. Im more confused now then before i posted 😆
  2. How do you.connect this app to read ?
  3. Can someone plz confirm what the new price will be for a 2023 L&K Superb when its due this september ?
  4. So many different versions . The newer one is apparently 80k but there is absolutely nonway i would leave it that long!
  5. So are we sayimg the filter needs doing then and Rainworth Skoda are wrong ? They say mine has no filter ? And they say 80k miles . I want it at half that miles and chNge the filter if it gas one . Imcannot believe how many specialist garages are saying different things .
  6. So Called 5 garages up for quotes for this. 2.0 Diesel 2023 7 sp box . Some say it needs a filter and 2 said it doest and one was Rainworth Skoda. Do I go with the main agent as correct ?
  7. I honestly think its a software issue . Mine was lost when i discovered it whilst travelling on the M1 . Tried a soft reboot ( hold power button ) and it didnt work. What did work was when i stooped to fill up and turned the engine off and 5 mins later started it up all was fine . Its a glitch and has to be firmware imo.
  8. No Idea what spray is as i didnt use it, i just got used to the noise it wasnt that bad on mine .
  9. Is that a trip to the dealer for an upgrade?
  10. Its the mechanism inside the vents, my 17 plate did it ( not as loud though) i think you can spray stuff inside to cure it.
  11. Not sure ill let you know when check it again . Sometimes ive experienced a bit of interference on DAB then i changed Radio stations akd still there then it was there for a call, i ended up rebooting it and it went.
  12. Can i ask what made you go for an engine flush ? Ive had mixed reports regarding these amd because i change oil regularly im not bothered with a flush.
  13. Just an update this happened whilst i was travelling, when stopped and engine turned off to visit a fuel station all came back on as normal ? So currently working again. Strange .
  14. Thanks will try that.
  15. 2023 (73) Superb L&K (canton) Head unit works fine but absolutely zero sound from anything, ive even tried to select different ringtones and nothing. Its a 2.0 diesel not that this should mean anything. P.S tried a reboot by holding power button too. Anyideas?
  16. I have a 2023 L&K and as you say the drive mode reverts to Nomal every time you re start the car but for a clear indication inset the ambient lights on auto and this can remind you earlier . Tbf the drive modes in the 23 car are some much better then the old 17 plated one, the sport mode is way more punchier and the normal mode is an all round decent mode to live with.
  17. Exactly what ive been doing . Thanks for that .
  18. I do an 10k oil change every 6- 8 weeks ! Thats how many miles im doing . UK based , use decent fuel and use TPS branded oil ( quantas 0w-30)
  19. Would it be advised to run an engine flush through my engine every 30k ? Its a 2023 2.0 Diesel 7DSG Superb that is used mainly motorway driving but in constant use . I was told these late engines are prone to 'clogging up " and would recommend a flush however some people dont advice of using flushes due to potential chemicals that could do more harm for your engine ?
  20. Any idea on replacement intervals on a superb 2.0 diesel 2023 ? Do these need specific tools as well like spoken about above ( post ) ?
  21. What box is in the 2.0 tdi 2023 ? Are these also having issues ?
  22. So what you saying here stick to 5w/30 and go against VW / Skoda recommended?
  23. Yeah i think that also could be accurate.
  24. Im now 900 miles away from the first oil change ( I do enormous miles ) ive used about 1litre of oil as a top up that will probably work out per 9k miles. I done some research and apparently this is normal for all modern cars as the higher spec oil is much more thinner and does tend to burn quicker. However the offset to this would be better mpg and more environmentally friendly. Will keep an eye on things though but for anyone else reading this 1 litre ( even maybe 2) is normal per service interval.
  25. Think thats correct however is there much difference between the official recommended 0w20 over the TPS recommendation that is 0w30? Re the 5w30 thats only top up oil.
