Everything posted by deepshegde
Amundsen MIB2 Firmware Update
@pab567 Need your help with MIB2 Ambudsen STD FW upgrade. I currently have fw 359 and wish to upgrade to latest i.e 480 in the process getting error. Attaching my device details and error. I am planning to retrofit virtual cockpit on my superb mk3 2017 and need to be able to display maps but do not wish to upgrade my headunit. I downloaded fw from link provided in this video
Hello, Mine is Ambudsen MIB 2 Unit.. Can someone recommend me firmware update? Installed SW train version: MST2_EU_SK_ZR_PO359T Installed SW MU version: 0359 Part number: 5000358648 Software version: H28.28.133_STD2Nav_EU I am looking to upgrade to virtual cockpit on my Skoda Superb MK3 2017 and thinking of ways to display maps and someone advised me to upgrade to 480 but not sure if it involves any problems.
Midway through MIB 2.5 upgrade looking for coding advice
I am looking to upgrade my superb mk3 headunit to MIB 2.5. Sharing pictures of headunit and control unit in glove box. I wanted to know if there is any way to just upgrade firmware on existing control unit and change headunit hardware to newer one? Would appreciate guidance here.
GENUINE SKODA AMUNDSEN 2nd MIB SAT NAVIGATION SD CARD UK
Are you saying aftermarket SD card worked on Ambudsen MIB 2 unit worked? I am little apprehensive as skoda software update manual says only skoda sd card will work with the unit. I dont mind buying one but if it didnt work then it is of no use to me...who uses SD cards nowadays its thing of a past 🙂
Skoda SuperbIII 2017 virtual cockpit
I got this part in Aliexpress @Frankenfurter@ApertureShttps://www.aliexpress.us/item/3256804951873643.html?spm=a2g0o.cart.0.0.783d38daEdpDNL&mp=1&gatewayAdapt=glo2usa. However listing says its skoda octavia part...I'd like somehelp to confirm if this would work on my Skoda Superb Mk3 2017.
Anyone here help me find exact part number of SD Card compatible with my car Superb 2017 unit Ambudsen.
Ok basically, SD card from market wont help then
@Schlads2020I am in the same boat as you bought 2017 Superb. I tried it using 16gb card but skodas instruction manual itself says aftermarket SD Card wont work. Any luck with yours? Read point no.1 of this manual here : https://updateportal.skoda-auto.com/Download/amundsen_MIB_2.pdf
6" to 8" display upgrade
I didn't buy anything. These came stock with my car
Is it possible to enable wireless android auto / CarPlay on my Skoda Superb 2017 model? Attaching pictures of my control unit- 5Q0035864B and my headunit which came stock with the car. Wired android auto works fine.
I tried finding right steering wheel buttons for my car Superb Mk3 2017 DSG as i am planning for a VC upgrade..Unable to find 3V0 919 719 F (DSG) on AliExpress. Can someone help?
My Superb has swallowed my wife's blue card
How to open superb 2017 center console
Folks, Does anyone have any knowledge how to open this part? My cup holder slider is broken and needs replacement.
My Superbs DRL turning yellow
@Danoid yes, turn indicators work perfectly fine..its just that white DRLs faded ir turned yellowish. See video. VID_20230607_181719.mp4
Thanks folks...just wondering if it is faulty led module then would ut not throw error code?
This is great work @igordeluxe 👏. Can you pls share steering wheel button part number?
I have this problem with both my headlamps unfortunately, does driver module comes as seperate part or its part of assembly?
Any experts here to comment abt a problem with Skoda Superb 2017 DRLs tuning yellow and light itself is very DIM. Any DIY solution instead of replacing headlights which costs bomb!
Thanks frankenfurter. Can you help me with part no if know it already? I reached out to VAG retrofit who can help me code remotely using VAS5054s and they said 3VD920790 is the right part number for VC
I have Skoda Superb 2017 in India.My question is can i install virtual cockpit? Any guidance around part numbers and actions needs to be taken to make it happen?
Virtual cockpit on Superb 2016
I have Skoda Superb 2016 in India..Head Unit is MIB2.5(upgraded). My question is can i install virtual cockpit or does it require BCM upgrade as well?
Skoda Superb 2016 Virtual cockpit upgrade possible?
