Stonekeeper
Everything posted by Stonekeeper
  1. If no-one manages to come up with the code for you it may be worth checking out https://www.carparts4less.co.uk/about-us For their prices too Fulfilled by the same company and sometimes cheaper Both site have a rolling discount code in the top banner but different and different minimum spend for free delivery.
  2. Make sure you read the "Supported devices an files" section before putting your music on the stick Particularly the part about DRM protected music https://digital-manual.skoda-auto.com/w/en_GB/show/f74d8560289d9d35ac1445255362cfe0_10_en_GB?ct=f74d8560289d9d35ac1445255362cfe0_10_en_GB#titled86259682e97455
  3. USB for stick is positioned at (I) the one at (E) is charge only When you looked in the glove box was there no Owners manual? https://digital-manual.skoda-auto.com/w/en_GB/show/56d21ecc816625f70e4b57d70b2854eb_9_en_GB?ct=56d21ecc816625f70e4b57d70b2854eb_9_en_GB#titled86259682e204553
  4. https://digital-manual.skoda-auto.com/w/en_GB/show/19426271f5a28bdb18174b8efdc3651c_2_en_GB?ct=19426271f5a28bdb18174b8efdc3651c_2_en_GB#titled26553038e38350
  5. How the dsg works and why those services are important
  6. Probably the new powertrain from the Passat that increased electric only range to 62 miles
  7. https://www.honestjohn.co.uk/real-mpg/
  8. https://ownersmanuals.blob.core.windows.net/ownersmanuals/en/Octavia_5E/05-2015/Amundsen_Bolero_Navigation.pdf Page 39 onwards
  9. Not all usb cables are the same. Genuine phone cables supplied with the phone usually charge and transfer data but some third party cables only provide power. So initially i would suggest trying a different cable
  10. Salt water (sea) and freshwater (rain and rivers) have very different properties? https://socratic.org/questions/why-is-seawater-a-better-conductor-of-electricity-than-water-from-a-freshwater-l
  11. Many after market dashcams are set to switch off when the ignition is turned off/stops receiving the 12v feed.. You can sometimes change this setting in the cameras menus to allow the camera to continue to record for a period of time.
  12. i don't think Smart link is needed for the phone to work for calls. If you have changed phone you may need to remove the old ones details first Here is the manual https://ownersmanuals.blob.core.windows.net/ownersmanuals/en/Rapid_NH/05-2015/Amundsen_Bolero_Navigation.pdf From page 30 watch for prompts on the phone as well as the unit whilst pairing
  13. hola charly. Bienvenido al foro de mensajes. Obtendrás más respuesta si eres capaz de traducir tus publicaciones al inglés.
  14. It is not compulsory though is it? Does the car still have smartlink to connect your own phone to use your own existing data plan if you have one? Personally if a car doesn't have integrated satnav i won't be buying it. I have very limited resources for paying non-sense subscriptions.
  15. It has a towbar and skoda have won towcar of the year awards many times with the caravan club so it's a good bet.
  16. I would not rev the engine of the donor car whilst jump starting either. If the leads are decent quality and properly connected it should not be necessary. Your starter motor is connected to the donor cars battery. Positive to positive pole and negative to chassis earth point
  17. Depending upon how hot their exhausts were when diving into that cold water, the emissions tests next mot time will be interesting with possible failed catalytic converters
  18. I don't think i would be worried about the tyre, on the rear at 60,000 miles it could be an original that has just come to the end of it's life after hitting one too many potholes or been underinflated when towing the caravan. It appears to be a long way from you though for you to go and have a look. The mot and timing of sale is probably just to get the best price for the car, The one owner has done roughly the same miles each year too which is consistent. has always took it for an MOT ahead of it's expiry date which shows some evidence of care. You could do with seeing some interior pictures and service history?
  19. I think it's £72.99 per year for up to 60gb
  20. Is there a spanner next to the sos button? If you have paid the subscription i think you can push the spanner next to the sos button?
  21. Sorry to hear of your issue, glad it sorted itself out, Is the SOS button you refer to different than the one that calls emergency services in the event of accident or need for medical assistance?
  22. 2' 6" deep, They are mad
  23. I have had similar when it turned out to be a mis-shapen tyre.
