Everything posted by radoszczak
Software Update available for Bolero?
As I see adjorek had 1790 fw so he should update to 1800 with no errors.
- Bolero MIB1 Update Help Please!
Try to reset system, hold power/volume wheel, and try update again. Are you do it with all sugesstions ? Engine off, ignition on, charger at battery, native pendrive directly to usb port, firmware files unpacked correctly to storage ?
DIY Battery replacement on Skoda Scala
Hi, my 2021 scala have problem with low battery warnning on the dashboard. Car is riding on short distances, but battery seems to be in good health by idle voltage messurement. About 12,4V after few days off, and above 14 when engine is running, so charging is working well. Is to possible that 3 years old battery is poor ? Car was using start-stop at previous user. I have also messeges at infotaingment says: low battery 12V, need to charge when engine is running, high power consumption etc. Car is starting whitout any problem so far, but winter is comming, and I wondering shoud I change battery.
Hi. have you read this topic ? All answers are in. Here you have link to the firmwares. The newest is 1800. https://disk.yandex.ru/d/1V1uBTc8ssc3zA
Try 464. It's possible it will be ok. Is it something wrong with your system ? Maybe you don't need to do the update?
1.5 SEL first gear issue.
Anyone know that this kangaroo thing whlie starting could do any harm to car's drives system like engine, clutch etc ?
https://easyupload.io/oeqq39
Air con service after two years?
Hi everyone. I'm wondering should I service my AC in skoda scala 2021 ? AC works fine, car has been bought this year, after warranty. I have 1234yf gas in system. I've change cabin filter. Is there service intervals for ac even if it works fine ?
No warranty. Car was bought after 3y warranty without expand.
Would you tell what to do mean by right equipment ? Special diagnostic tool ? Computer with right software ? Maybe it will be possible to update it in car workshop near by. Unfortunatly manufacter service won't answer about update, so I need to find a car repair shop, or leave it and drive with this unconvinient sympthome. Anyone can tell does this kangooru could harm any mechanical devices in car, like clutch or two-mass wheel ?
Have you read this topic ? All answers are in. Links to the fw too.
I see. So only in dealer service workshop it can be done?
I have found that newer version of fw for my ECU is available but I have no idea how to download it from quoted site and how to update it in car. Is it simmilar to update infotainment system?
Hi, please tell me, you were update to 1910 version by your dealer ? I think I have the same problem o my scala 2021, obd11 show that I have 0807 version. There is no way to update it by myself perhaps? My symptoms are simmiliar to all described here in topic. When I'm trying to run, moving the clutch without acceleration pedal, and when clutch is almost off, there is a moment when I instantly put acceleration pedal in even no secound there is like lag, and jerky acceleration of car. Maybe updating fw engine will help me too.
Fw 1800 resolved android auto failure with samsung s23/+/ultra. I didnt see anything else with this fw. Yes. There is risk to brick your system. Update only if you have a reason, not for fun IT is no a game.
Zero faults. All smooth.
A/C not so cold.
I confirm. I have just get a/c service and I had only 150 g of cooling gas. My a/c system should have 500g. Whistling noises in dashboard is symtopm of low cooling gas in system - as you said. But my problem is larger. I have change condenser last summer and I have checked cooling gas at spring, it was full. Now after 4 months seems to be leak, 350 g of cooling gas was missing. Another sympthom that I had was low metalic noises on idle when I accelerate, only with a/c on. It stops after last a/c services in winter. Someone has simmilar problem ?
Hi, I have successfuly update sw directly from 1310 to 1800. Android auto works with s23u after update. It lasts about 20 minutes.
Download FW https://easyupload.io/p9xaox MSTD_EU_SK_P6230 (0490) Unpack archive to sd card or pendrive (min 8 GB) fat32 file system Unpack files directly to root folder of mass storage so the car could see it Prepare charger for battery in your car Connect charger so battery will not lose voltage when update will proceed Turn ignition on, engine off Press menu button for about 3-5 sec Get into service menu Choose right mass storage usb/sd card Follow instructions DONT'T turn ignition off while update All at your own risk - there is small risk that you can brick your unit Good luck
I ment this answer added by andreiro221.
