blackh0le
Everything posted by blackh0le
  1. You need Crystal Lightning on the rear. Some packages had it included.
  2. I mean this 1941 - TPI It describes the type of problem that Skoda considers eligible for the new software installation.
  3. You could turn of the car with CarPlay on display in the Infotainment, so the infotainment starts directly into CarPlay on startup. This workaround works for me
  4. Isn’t this the space where the Trop Down Menu handle is shown when you go near the screen? Don’t know if the infotainment can draw above the CarPlay Window
  5. That’s good news. So do you need to match the ABT software of the old one? Is there no component protection?
  6. In pre Facelift, you can activate an option in your Infotainment for Autolock via OBD11
  7. Try the next time when you leaving the car, Android Auto open on the Infotainment-Screen. So when you get back in the car the next time, it starts directly into Android Autoand not the Skoda UI. Had the same problem with Cover and Calls no more shown in Dashboard after getting 1985 with Apple CarPlay, read this Trick somewhere and it's a workaround. If you have an OBD Scanner, most likely you will find Code U105400 in the Dashboard.
  8. What Software version is your Infotainment running?
  9. Since we’re on the topic, where does the Matrix light get its information from? There are places that are clearly within a town, yet it activates for just a few meters, or it takes a long time after passing a town sign before it deactivates.
  10. As far as I know, VW uses map data from “Here Maps.” At https://mapcreator.here.com you can submit changes.
  11. As far as I can remember from other threads, the part number corresponds to the initial firmware of the unit. Sometimes it gets changed up with updates. And just to mention it briefly, it seems that 19855 is no longer the latest MIB3 firmware. I’ve read in Capra forums about OTAs to 1988.
  12. What’s with the Plugs when changing the steering wheel? Is there some adaptation needed or just plug and play?
  13. What you mean redesigned? Does it look totally different? Would you share a picture?
  14. Then I would recommend you use CarPlay via USB Cable as a solid connection
  15. When you connected with CarPlay wireless’s and open the Phone App of the Infotainment, it asks if you want to switch to Bluetooth connection for the Phone. Then you see all the Phone Data you allowed in your BT Connection with the Car in the infotainment. While CarPlay is connected I think the only way to Phone Contacts, recent etc is through CarPlay on the Infotainment Display, Siri or the Virtual Cockpit
  16. The data sheet for the 1.5 e-TEC talks absolut 4 cylinder
  17. Did you give in he phone permission for contact sync? What phone you have?
  18. Has anyone else been having trouble sending a route from the app to the car?
  19. Hi, I'm bringing up the old thread again. Does anyone happen to know if it's possible to activate the Canton equalizer interface with the presets (like Speech, etc.)?
  20. Mine has this too. And it won't refresh Apple CarPlay Titel Covers. Heard from other too
  21. In which module did you encounter the error?
  22. With Bolero Infotainment you can buy Navigation in Shop, I think.
