Everything posted by OccyVRS
Heated windscreen - Can you see the wires?
AFAIK on cars with ADAS, you really want to be using genuine glass. Mine is scratched to hell - not quite sure how, but there we go. The replacement cost is eye watering, so I may just wait until that stone gets kicked up from my mates car...
Hi from Southampton
Well, that's being scrapped it seems! The Octavia seems to be the first car that fits me well. I am 6 1", but my height comes from my torso. In other words, to have the seat set at the right distance from the steering wheel, my feet are usually stretched to reach the pedals. The Octavia seems a perfect fit. I had a courtesy Golf with the dead pedal on the right side too. I liked it, but none of my cars have ever had it. I usually just plonk both feet on the floor, perhaps slightly under my seat. It's not ideal, but it's better than putting them underneath the pedals like I did in my Leon. My previous car to the Leon (A3) had the accelerator hinged on the base, so while it was much better for heel toeing, it made shoving my size 12s underneath it a bit tricky!
Tyres for octavia mk1 vrs hatch
Generally speaking (trench blocks come to mind), you'll bust the suspension or structure (boot/cabin floor) before having any issues with tyres. it's actually quite difficult to go over the max load for a passenger car, unless you are transporting lead or bags of cement. The extra weight is definitely noticeable, no matter the car. I notice the difference with just a full tank of fuel. That's not to mention if I put a suitcase or two in the boot, the front of the car becomes a monster truck. Stiffer springs are definitely needed.
1.4 TSI (150bhp) Modifications / Improvements
It turns out my MacBook didn't like the word backbox. I would, of course, discourage a backbone delete - it would be uncomfortable. A backbox delete is maybe a consideration if you have a 4.4L V8. In this instance though, as said, it'll just create a racket. I was always told to never consider one below a 3.0 V6 and even then, it is a mixed bag. You can get anti-drone sections for a res delete.
Apologies - by VAG CB I was meaning VW Audi Group centre bore. In other words, the exact hub spacing of 57.1mm. By using hub centric spacers you're absolutely fine, however I just wanted to mention it, as a surprising number of people don't use them. I would personally avoid a backbone delete. It will increase the noise significantly, but in much more of an ASBO way than an enjoyable way.
Trying to save a Fabia in a 5th world country
Perhaps a silly question, but why not just do the work yourself? You seem to know enough/be able to find the answers or, at the very least, more able than your local mechanics. I'm not sure where you are, but I can see one or two VW places in Santa Domingo. +1 on what Alasdair said - one notch or two you'll likely get away with it, but any more and you can have some serious problems. On a side note, the 1.9 SDI differs from the 1.9 TDI in that it has no turbo. From my understanding, while they are painfully slow, they are generally absolutely bomb proof and very good on fuel. Buena suerte. ¡Valdrá la pena!
TSI engines
It's a small engine working hard. I've seen them get well past 150,000 miles without issue. That said, aside from a beefy diesel, I personally wouldn't want to own any newer car past 120,000 miles. Too much is plastic, which is affected by heat cycles.
Can't open driver's window without holding onto button
One touch window needs resetting - have you had the battery changed? IIRC you need to start with it up, put it down and hold it for ten seconds, then release and put it up, holding at the top for ten seconds. Something like that anyway.
Octavia Mk3 steering wheel controls - right side wheel not working
SKODA Parts DirectSkoda 2014-2024 Multifunction Steering Wheel Push Button...SKODA Parts Direct | Genuine SKODA parts cheaper than main dealerships | Shipped straight to your door. | Skoda 2014-2024 Multifunction Steering Wheel Push Button SeteBay UKGenuine Skoda steering wheel switches 3V0919719A. Fabia O...PART NUMBER: 3V0919719A. Genuine SKODA pair of black MFSW steering wheel switches. Genuine Skoda steering wheel switches in excellent overall condition. Theywere removed from a Skoda Superb (3V) st...eBay UKSkoda Octavia Superb Mfsw Yeti Multifunction Buttons Stee...Skoda Octavia 2 Superb 2 Facelift Yeti Multifunction Buttons Steering 5E0919719f Full working order It is used so may have marks Please match part number All items are security marked. Postage is u...
Squeak and rattle
They might suspect it is the clutch pack, which is not covered by the warranty as it is a consumable item. I personally think this isn't fair on DSG boxes, but there we go. Here is the booklet. At this point, I've just deleted the rest of the post I'd written. I was going on about how it was completely the fault of the dealer, etc. However, when I went to check the age of your car (I was advising to visit an Indie VAG place for service records) I noticed that it was a 1.5. This car is fitted with a DQ200 gearbox, which has no service interval. Regardless of the nuances of this (my gearbox is set at 80k miles, however I'm having it done now at 35k), the dealer had no obligation, responsibility or need to service the gearbox. It's good practice to replace the fluid at some point, however as it is a dry clutch box, it is a sealed for life unit. Certainly, at 40k, a service isn't really needed (age aside). TLDR - if the gearbox in general is at fault, then you are covered. If the issue relates to the clutch pack, you might have an issue. May I ask, is the issue prevalent when changing gear, or when actually pulling away? The two major issues (not DMF as they would have said) are the clutches, or MCU (mechatronics). By the sounds of it, I would be more inclined to suggest it is unfortunately the former. However, with only 40k on the clock, I'd be surprised if the clutch packs had an issue with wear. It's a bit of a cop out on VW's part, but the warranty isn't really there to help you is it?
Battery change
It doesn't work like that - a new battery needs to be coded in, regardless of whether it is the exact same make, model and batch as the old one. If your car is a late Mk3.5 you'll enter the world of ODIS as it's a locked gateway. If it's earlier than that then you can use any decent system (VCDS, OBD11, etc). OBD11 can be had for around £70 (last time I checked) and will allow you to make the required 'adaptation'.
Mk3 Brake Pads
OE would be my choice, as OEM can sometimes be a bit iffy if you get the cheaper under licence ones. Ferodo are very good, as are Pagid. Brembo are crap unless they are proper ones. EBC are nice, but I'd choose OE over all of them for normal use with a stock vRS. I ran full OE on my 350bhp vRS before swapping to DS2500 on the front. The car is back to 250bhp and the pads haven't got ages left, so I'll be putting some OE ones back on. BTW - OEM are TRW/ATE pads. OE are the same TRW/ATE pads, with the VWAG stamp on the back, in a VW box.
Hi from Southampton
Ah it's always backed up there now. It ends up blocking Thomas Lewis Way, which is busier than ever thanks to the 20mph.
Re the res delete - £50 may have been on the low end, however I still stand by it. If you're wanting an anti-drone section then it'll be more, however ultimately a simple res delete is a bit of straight pipe and two welds! If you're able to change a wheel and get some 57.1mm (VAG CB) spacers, I don't see why you'd have an issue - it's virtually the same process as refitting a wheel normally. Issues only arise when you're messing around attempting to centre spacers and the wheel. You can change the waste gate actuator clip which does help, however the linkage naturally has a bit of slop in it. I honestly can't remember how easy it was to access, however I think nothing had to be removed. https://www.golfmk7.com/forums/index.php?threads/how-to-fix-the-turbo-wastegate-rattle-on-the-mk7-golf-1-4lt-tsi-140-150ps.340805/
All @travs was on about (I think) the risk of spacers being installed improperly, or causing premature wear on bearings, hubs, etc. In theory there’s no difference between a super high offset wheel and a 30mm spacer, so as long as they’re installed properly, centred, etc, you should be absolutely fine. I would hope any decent performance/tuning/exhaust place can help you. I wouldn’t expect you to be paying more than around £50. P.S. you might also want to look into sorting the turbo wastegate rattle. It’s a common issue on all these cars - when in 2cyl mode, the sound is annoying. I remember my Leon was particularly horrendous!
In line with what has been said, the most power you want to be putting through these engines is about 180bhp. Anything north of 190bhp you start to risk breaking things. Even if the engine internals can cope (debatable), the cooling system, gearbox, etc, isn't. Best case scenario, as a lot of 150ps Leon FR owners found, you'll knacker the clutch. I'm not too sure about Hankook, but something from Michelin or Continental could be worth a look, depending on your tyre size. Pads and discs depends on what you're after. Something from EBC or Pagid could be worth a look. If you're going to be doing spacers, some lowering springs might be nice too. You don't want to run huge spacers IMO - if you're after anything more than 15mm or so, I'd get some different offset wheels. A res delete is literally cutting the/a resonator out and putting in a put of straight pipe - it's generally a quick 'custom' job. FYI @netman82 this isn't true at all. Even if you run an open cone filter, nothing is getting through any filter.
Hi from Southampton
Hopefully it wasn't on the Avenue by Boldrewood!
It's worth saying that a few mm make no difference (as long as it goes the enture way through the thread) but you don't want them to be silly long - that can cause issues too. Anything bolt wise, you want to get from Bimecc. McGard Black Edition are the lockers to go for. That said, I only used the lockers as I got them in a deal from wheelbase alloys. Were I paying full price, I'd just run five normal hex bolts. I've had a lock key round out on me. It was a nightmare, until I had/found the idea to whack on a blank socket. It took me literally ten seconds to remove the locking nut/bolt. This was a Focus with the scrappy Ford two-piece design, but you get me drift. I wouldn't remove the lockers from my car, but were I buying again, I wouldn't personally bother IMO.
Yep - it's just a cost saving method really, although in my Leon I used to like clicking into full power mode! Dogbone mounts will have an effect - they're used to reduce transmission movement during acceleration/deceleration. They have more of an impact on DSG cars, but small things add up. Speaking of small things, the diverter valve they're on about is here. Truthfully, I think it is a total waste of time on your engine. A diverter valve works by diverting built up boost pressure when you lift off the throttle (similar to a BOV - blow off valve). An upgraded DV is useful for reducing spool time, thus increasing throttle response, and a BOV is useful for quickly dumping the insane amounts of boost your 110mm Garrett turbo is (not) making. For example, the GFB version opens 10% faster and shuts 50% faster than the factory bit, which helps you build up boost a tiny bit faster. It'll help with throttle response, but it's not really important on a Stage 2 RS3, let alone a remapped 1.4! If you're after throttle response, a pedal box will do far more. It's the same story with fuelling, plugs and whatever else you can throw at it. These are all supporting mods to the elephant in the room - the turbo upgrade. You could very easily drop £7,000 by squeezing on some Racingline carbon ceramic discs and six piston monoblock calipers. Will they make any difference? No. What tyres do you have? Did you just do the K&N box, or is it the cone style cold air intake? Putting some PS5s on, nicer pads, spacers and maybe a resonator delete will do far more for your driving experience than pointless unsupported engine parts!
Discs& disc pads
That's £456 a year. Take away £45 for the MOT and £25 for breakdown, £386 is quite an expensive service (especially for an electric vehicle). The warranty is quite nice, but after you've paid the mandatory investigation fee, you may as well just pay for the extended warranty out of pocket. There's a reason they're called stealers - they are there to sell you a car and take your money. This is personal experience - from being sold a crash damaged car to being assured by a master tech the rock lodged in my subframe was just old age sounds of a 2018 car. Useless.
Brake pad wear sensor triggered after 24k km / 15k miles
I suspect it's a sensor issue. My DS2500s are due to be replace soon, but they aren't OE pads and have seen some very heavy use over the last 10,000 miles.
Discs& disc pads
I've never found any dealer to have capability, confidence, trust, value and rapport. I've always found indies to do a better job, even if it is not always cheaper.
280/272 estate buying advice
Just a further 2p from me. Fabric interior - bit more of a pain than leather, but when not cooled, I think it's much better. My vRS is the first car I've had that isn't leather and I wouldn't go back. Having a wet vac does wonders. DCC - YMMV. My Occy doesn't have it, but my mums 1.0 Ibiza FR does, weirdly. I can't say I notice much difference, but that may be down to the car. Not sure about them going any quicker, but they are significantly more expensive to replace. VAG pan roofs can be quite a pain - leaking is very common from the drains if they aren't cleaned regularly. Boot struts +1 - my vRS struts failed after a few months. Having felt the weight of the hatch lid when replacing them, I'm not suprised. The power assist ones also (according to this forum) have a high fail rate too. Gearbox - I've driven the DQ381 box in my car and a DQ250 in a GTI. I found the DQ381 to be the slightly tighter box (possibly as the ratios are shorter) and the extra 7th gear is nice for motorways. There were some gripes with it, but it's tuned now and is perfect. I also find that the gearboxes vary hugely from car to car. The DQ200 in the aforementioned Ibiza FR is fantastic - it's the reason I ditched the idea of a manual Cupra 280/GTI and got my DSG vRS. That said, I've driven the same box in a few other cars, and it was absolutely awful. Does the Superb have different mapping/setup to the vRS and others? Maybe. MPG wise, while I can't comment on the specifics of the previous commenters car, I can say that I do believe GPF cars have poorer economy when they are cold. Certainly, when in traffic over winter, I struggled to see double digits in my mapped vRS. Recently however, when doing a very long (30 miles) stretch of 50mph average speed, the car apparently clocked 50mpg. Not sure how much I believe it, but the car was still running 350bhp then, and that's not bad.
Man-Made Climate Change: The Need for Immediate Action
It is one of the more interesting sweeping statements I've seen recently! Regardless of the various arguments about the Anthropocene, I would just like to add that when these countries (emergent, may I add, rather than developing - with the exception of the hybridised China) were virtually net-zero, much of the 'developed' world was busy with the industrial revolution, followed promptly by two world wars. I'm not entirely sure where the regard for climate change was throughout the industrial revolution. Certainly, neither WW1 or WW2 were very environmentally concious, not to mention more recent developments such as nuclear weapons, the space programme or air travel. I mean let's not forget, it wasn't China or India that invented the environmentally-crushing internal combustion or jet engine. I'm not saying the Chinese are guilt-free with regards to climate change, but this isn't in Europe -
England-wide Meet and Drive!
Well over 100 people in the meet now - anyone else fancy joining? We've got Octavias, Fabias, Superbs, Enyaq, Karoq, Rapid and even a Favorit!
