Everything posted by KirkJames
Superb Air Vent Removal/Fitment
Go for it mate, was very straight forward. I actually need to do mine again as I broke a vane using a cheap phone holder.
Hi Jim, I wish I could help here. It was the right fit for my car which is a MK2 2.0tdi L&K. Other than that I don't know what fitments are needed for any other models. You will need a pulling tool though for taking vent out.
What sun visor clip do I need
Whereabouts did you get that from?
2 and 3
Hi all, Can't seem to find what sun visor clip I need. In typical VAG style there's about a million different ones. Can somebody help me out please.
Sunroof Replacement
Thanks Softscoop, I haven't heard od them before but worth a message. Thanks for the steer.
Sunroof Replacement
It's a normal sunroof. As in one piece of glass tilt and slide. Although mine hasn't tilted or slid for some time. The trouble is you have to be very careful because there are so many with really small mounting differences if you get one from abroad and it's wrong, unless you can sell for the same money you are wasting cash. Appreciate the links though I will take a look.
Sunroof Replacement
Hi mate, yeah quite a few. Why is there such a lack of them? I am baffled!!
Sunroof Replacement
Hi everyone, I need some help here because I really am at a low point with my ownership at the moment with all the things that I have had to have done and the money spent this year. I have to get the sunroof sorted and need a donor cassette (my rails etc broken) and there are just so many different variations of the sunroofs and a distinct lack of spare parts (even from abroad). I am at my wits end so I am calling on everyone to try and help source a donor cassette please. It's a L&K mk2 saloon
water ingress drivers footwell?
Glad ypu got it sorted mate.
That should work
I think it should but be careful. The other side was fine, very fiddly but got there in the end. If in doubt drop the headliner to make sure it hasn't detached anywhere.
Relatively easy mate. Probably worth buying some Sunroof Drain Cleaning Tool https://www.amazon.co.uk/Sunroof-Cleaning-Flexible-Cleaner-Dredging/dp/B0D386J5V7/ref=asc_df_B0D386J5V7?mcid=4ed78293fc46368c8a7952353cfc4213&tag=googshopuk-21&linkCode=df0&hvadid=730369837808&hvpos=&hvnetw=g&hvrand=16093744783223272607&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9045093&hvtargid=pla-2398180781187&hvocijid=16093744783223272607-B0D386J5V7-&hvexpln=0&gad_source=1&th=1 If that doesn't work try pulling the headlining away around the sunroof and looking to make sure the rubber grommets/connectors are actually connected. I cleaned my drain lines from the sunroof (as you don't need to remove the headliner for that) only to realise that I had knocked the grommet away from the drain hole from the sunroof which then led to water running down into the footwell (because there is a drain hole near front of the drivers door)
Oil Dipstick Tube
Thanks matey, Ended up buying one slightly higher price in the end and anyway and it's now safely on the car. Appreciate the link though 👍
Oil Dipstick Tube
It's for a Skoda Superb 3T
Oil Dipstick Tube
Hi, I am after a replacement for a dipstick tube for my CFFB Skoda Superb 2.0tdi. Why is it that I seem to see a lot of these horrible yellow replacement tubes etc (no thanks) and the only like for like tubes seem to be quite dear? I'm at a loss as to why! Anyone point me in the right direction please. Happy for a used one. My VIN is: TMBBE93T********* Your model year, car and engine type are enough info for what you require. Please use the Briskoda messaging service for the echange of VIN codes. This is to help prevent plate cloning. Thanks, Briskoda admin.
DMF Replace
Very interested in seeing how this goes. Good luck mate.
The Inevitable Throttle Body Clean
Okay I have bought the OBDeleven 2 pro so I should be able to do adaptations now. Is there a guide anywhere?
Just an update here but I have been noticing for a little while that I get a slight shudder when pulling away (more obvious when cold - and its not the clutch as was inspected recently) also the old hesitation then bang you're off. This happened last time before I cleaned the Throttle Body (when I had the P0121 code pop up on my Veapeek) But..... I have been researching a little more and this could all be signs of the TPS. I can get another for not too much cash but wondering if there is anyone near me (Norwich) that can do the Adaptation needed after I fit the new one myself?? Any help would be brill
- Recommendation: LED DRL daytime running light bulbs (Auxito)
How smooth should 6-speed DSG (DQ250) gearbox be?
Who are yoi asking? I had mine done about 2k miles ago by Skoda Specialist
Mine is also a little clunky (also recently serviced) at lower speeds. My old 2019 SEL used to be the same and that was brand new!!! I think unless you have a sportier model (better tuned DSG) or have the TCU remapped yourself I have always thought of them as quite lazy around town. Carriageway or motorway whilst you have your foot more firmly down is buttery smooth however.
Sunroof Replacement 3T0 877 049
