Everything posted by Redestate
The Festival of the Unexceptional - take your Yeti in a few years !
I've got a you tube vid from Steff I drive a classic to watch some time on that car show
I Love My Octavia
my diesel was from my local harvest petrol station in Gosport , and a large can of injector cleaner from DAF helped Car has had a full service in June with an oil flush
I Love My Octavia
335mls on half a tank of diesel
Octavia mk2 estate suspension questions ?
My 2011 1.6td estate has a saggy arse as it’s sitting low compared to front and pics I’ve seen of others The shocks were an advisory last mot as was an suspension arm for corrosion , What parts would you replace apart from shocks ? And where would you buy them from ? MOT due December
the truth about electric cars
I swapped from a MG5 to an Enyaq and there’s way more space in it and a lot higher
I Love My Octavia
My work hack 1.6 tdi 2011 is giving me 58 mpg and done 230 miles on a quarter of a tank
Leaking oil on driveway
Air con condensate washing off some protective grease ?
Repair or scrap?
The fact you’re already sourcing parts , you know you’re gonna repair it Crack on and keep us posted with the results
Repair or scrap?
Repair , if your happy with car and like it and that damage is only cosmetic Go for it as it’s only an uneconomic to repair write off nothing else Don’t scrap it for just that if it’s mechanically sound and road worthy With just the mirror replaced
OBD
Below the pull out cubby hole on Rh side of steering column at bottom of the trim , near door pilar front
The ease of getting in and out of an Enyaq is what made me buy one I had an MG5 before and that’s lower than my mk2 Octavia
Rear brake pads 80% worn
£450 🫨🫨 that’s steep , you’ve got a Skoda not a top of the range Audi
Octavia mk2 Estate tailgate struts replacement
Brought and dispatched and will be fitted Saturday when I’m back home
Clicking noise when turning steering wheel
Indicator cancelling mechanism
Well Otto’s tailgate don’t go fully up unless I push it up , Are the struts easy to change ?
- Looking for an Octavia MK2. MK3 TDI estate
- Skoda 2 0 135 kw VRS
Central screen replace with android screen? possible?
Factory Order Times
Estate first and fore most , as for sun roof if you really like it go for the SE Will you use all the toys in the sport ? But you’ll use the sun roof and the hound will be pleased with the extra space as well
oil light
If on the dash shaped like oil can you’ve got issues if that’s lit as it shows low oil pressure and needs checking out Service light no , but there’s a way to do it but I forgot
Andy
Hi from a fellow mk2 estate owner also own an Enyaq
Go on either eBay or Amazon and get the one that comes with the specific VAG canbus lead and box I’ve got this one in a SE , just waiting for facisa plate h
Airbag Error
I’ve got the same on my mk2 Octavia when I took the glove box out as passengers air bag deactivation switch is in there I’ve got a Launch diagnostics tablet coming that does SAS etc and has very good write up
Lane Assist and ACC
New under pants time in a truck and dangerous as it could cause a jackknife or roll over
