davojuri
Everything posted by davojuri
  1. Red led indicators and white led light
  2. Painted. Oe is only grey or beige
  3. Also installed updated trunk bracket With Rubber insullation all around instead of old one with tinny sponge strip at the top causing that bracket to cut through the paint at lower lateral edges. That's proper factory upgrade
  4. Let me explain in detsils process of rear Wings installation. I first removed heads of all 4 M6 bolts and made Spikes where there. I pressed the spoiler in place so the Spikes marked drilling points (Spikes where turned in minimally protruding). Drilled first 3mm,6mm and finally 7mm. Than we draw spoiler template on paper in place to get template for PPF. That drawing was scanned in A3 and than machine cut on 150micron PPF, it was placed in place and left to dry for several days. After that we did put double sided Wurth tape on the base of rear wing to gain amortisation,and sprayed With water mixed With baby shampoo to alow sliding od double sided Rape over PPF without distorsion of PPF before final Titanium bolt tighteming. Using PPF and double sided adhesive tape paint wont ne damaged after spoiler removal in futureπŸ˜‡πŸ˜‡πŸ˜‡πŸ˜‡
  5. Finally got W8 LED light in black
  6. That's how work should be doneπŸ’ͺπŸ‘πŸ₯‡
  7. Now only trunk left for painting-tomorrow Will drove car to the paint shop-finally has hood so I can drive it. But we removed new rear wing and will let paint to settle and cure for at least one month before installation to avoid new laque compression and bubbles formation. Looks bald without any rear wing☹️☹️☹️☹️
  8. Same thing happens in the back-trunk. There is a bracket With hadle and lock for it. When You lift the trunk holding it it also scratches the paint. Look at the pictures. Old factory bracket had small strip of sponge at the upper border. I thought about that and wantet to put also double sided tape and paint protection film at the bottom pressure points. But as I went to Porsche dealer in ETKA they offer protective strip-looks like old sponge strip and two small strips od PPF. Today I picked it up and it is real upgrade -full ruber insulation and two small PPF strips to go where it had damaged paint. Great OEM upgrade. I reccommend it to everyone.
  9. Small trick I used to avoid damage od newly painted hood from the grille which has mesh instead of rigid OEM insert meaning when You lift the hood over the grille You flex it and it scratches the painting on the hood so we did put double sided Wurth adhesive tape-narrow one 4mm apprpximatelly, to act as a damper, aside the fact that I don't lift hood over the grille but directly holding the hood lateraly from the grille
  10. Hood has came back from painting, grinding up to Trizact 3000, polishing with 3M green, yellow and blue paste.
  11. Full rear wiev of new rear wing
  12. That's Great plan. Originally I wanted original kevlar carbon WRC wing
  13. 330mm Audi quattro discs and adapters for OEM calipers
  14. First impression od the original Octavia Cup car rear wing is SIMPLY AMAZING
  15. I do6bt I Will. I wasafter WRC carbon kevlar wing,even guys in Czech Republic promissed to do one,but never realised that. WRC style is much nicer to me
  16. Original rear wing from Croatia Octavia cup car is ready, painted,grinded and polished, ceramic Gtechniq Crystal ultra serum and hydrophobic coating to come before installation.
  17. Finally got new water cooler made with tube fin core. Now time forctesting Bosch EBP with bar plate and tube fin cooler and Craig Davies EBP25 with both water cooler and by measuring IAT during full throttle load and water temperature we will see which one is the best combo
  18. Hood went for repainting, grinding up to Trizact 3000, than polishing with 3M green,yellow and blue paste at the end. Blue sheet is dust protection πŸ˜‚πŸ˜‚πŸ˜‚πŸ˜‚ Seriously considering wrapping the car in FlexShield transparent protective film.
  19. It seems no more leakingπŸ˜€. I've installed these bronze bushings on selector from 42DD, and replaced worn plastic ones
  20. Due to the unexplained oil leak (after removal and cleaning od the Setrab oil cooler) from both 90⁰ AN10 adapters I replaced them With New ones and also on passenger side New male/genske straight adapter with 1/8npt plug (had only one straight adapter). First test rub and no leak for now. Hope it Will stay soπŸ™‚
  21. KN HP3001 -extra large size in place. Oil cooler removed and emptied
  22. As I already wrote it's not about brute power but how to deliver it to the ground,smothness,go kart like drivetrain,monster breaking force etc. Blue colour is not tuning that I mentioned,only touch of class, but main thing is there are silicone hoses,ss braided hoses and top quality AN fittings. As for breaking 300hp it broke it already. Look at the dyno chart. 304 if I remember correctlyπŸ‘πŸ‘. Much more power is usless for 0-100kmh, only after 100kmh it make sense so no faster startups With FWD and 500hp...but aiming to do that via forged stroker, CNCed head,and forged valvetrain,G25-550....
  23. My friend You are the only one following my post,even there is no such complete build Like this one on the forum regarding every aspect of the car tuning..taste is a funny thingπŸ˜‚πŸ˜‚πŸ˜‚πŸ˜‚
