davojuri
Everything posted by davojuri
  1. Gearbox bolted on and filled with Motul Gear 300 LS, "dog bone", blu painted bracket for gearbox mount
  2. Flywheel bolted in place with new M10x25 1 pitch class 10,9 (couldn't found 12,9 and original ones from Febi that are 12.9 were to short-19mm only-less than 5mm protruding out from flywheel) so I went for the adequate lenght instead of 12,9 class. Had the same for decade without any problem. Sachs performance organic friction disc and pressure plate also in place
  3. Reinforced cutch fork repainted in racing red paired with Sachs performance release bearing
  4. And gearbox finally fine painted and assembled-ready to rock'n roll in the summerrrr🎶🎶🎶🎶
  5. Pay attention to fine precission tools and protein drink
  6. OEM LSD shims are 68mm outer diameter same as for the output shaft roller bearings but wider. We measured using dial gauge and reworked two new LSD ones 1,15 and 1,20mm and tried both, and went for thicker one 1,20mm. Great Job using some common sense without waiting monney.
  7. We succesfully measured with dial gauge required shims for the LSD, and input and output shaft roller bearings. Today we will assembly whole gearbox to check if everything is fine and dismantle it again for housing new painting in same colour but with industrial paint which is more resistant and durable.
  8. Those shims from Luk installation manual were for 02J, but my isn't any more. My gearbox is now 02S so I went to Porsche desler and took all the thickness numbers. Replaced previous 0,8mm for 0,85mm for LSD, now left are input and output Shaft roller bearings shims
  9. That's best wish You can think of. But for 4x4 I have to čut floorm9f the trunke for different reservpir etc-to much od a hussle. Guy eho did my gesrboh in Čačak Serbia did it on his estste-bb it evwry turn of the steering wheel there is strange Boise im the back. But for fast start it is a must. Now I can spin my tires in place even With my semislick until 3rd gear!!!
  10. I have it for almost 10 years and no it's not louder
  11. Getting ready for assembly. Just today realised I have all factory shims for LSD,but input and output Shaft roller bearings shimssre missing. Leftand right Ines on the picture
  12. Can't wait to put all that together and to eat for breakfast new Golf GTI,R, and others
  13. SPEC steel single mass flywheel SV21F completelly redone-ring gear zeroed first, new surface for friction plate and step height from ring gear to resurfaced contact surface for friction plate set back again to factory SPEC of 12,09mm. Perfect Job done. Now that might be a problem because they make difference in selling SMF for SPEC and Sachs pressure plate. Most od them use 12,4 or 12,5mm step for Sachs. We Will first pressure test it and measure with comparator when it disengages-how many mm. Maybe we get lucky or maybe we will have to resurface again to get higher step. As always commitment to details is important!
  14. Housing sand blasted and ready for repainting
  15. New OEM bearings and Sachs performance release bearing
  16. New Sachs performancea pressurre plate and organic friction disc
  17. Ready for further stripping od the old paint and primer
  18. Started stripping old paint and primer for renewal. Now when housing is disassembled fully will continue with further stripping
  19. Due to the vibrations and rpm increase while vibrating during throttle I remowed gearbox and clutch-time for new SPECSV363F STAGE 3+, flywheel resurface and gearbox overhaul while taken of. Clutch has more than 10y and gearbox has been last time serviced 2013 when changing also 1st and 2nd for custom ones as 3-6 already were. More detailed update to come, espetially how to resurface flywheel in proper way-meaning friction plate surface together with ring gear to pressure plate surface, and not only friction plate contact surface as my custom gearbox mechanic did than. Now I gattered exact proportions-height of both surfaces from factory so I can exactly replicate it.
  20. Just got my Smart 451 headlights finally done, and all the black parts on the side and above rear window painted in white together with real carbon front spoiler. Top! That's also heavy moddified car to. More to come-145-180hp!!!
  21. Yes,thanks nam. Still left to grind a little cylinder coil 4 to stay in Line With other coils,and to Mount back tfsi wire plastic cover so they are not so ugly exposed. But yesss I Like it more and more With time pass. Definitelly my choice of engine bay With all the respect to all other tastes
  22. After New Spar plugs NGK BKR7EIX-11 IRIDIUM I still fit misfires on cylinder 1 and 2. Now Just Got New Bosch coil plugs for Audi R8 latest revision 06E 905 115 G Didn't drive much but for now it seems problem solved. Will test more in upcoming dys to be sure. Hope that's iz. Badger5 reccomends that coil also.
  23. I have forge front Mount intercoolers sitting in in my garage because I went other way-water cooling. PM if interested. Plug and play. What part number are yours NGK?
