Everything posted by davojuri
- New Croatian VRS 236hp 19inches
Finally replaced Windows control module in drivers door-central locking, side mirrors and all 4 Windows are working. Replaced front Dog bone bushing for Powerflex black racing series one Now both are black. Waiting to replace rear Beam old Powerflex for New ones also Powerflex black racing series. Time for New Yokohamas Advsn Neova 08RS
Also some upgrade goodies for the headlight. As you all know they are full led made in Turkey, recently I replaced one set of H1 led lamps (outer projectors, passenger side was gone) and I noticed they do not have separate cooler what is not tje best solution. I used ones bought in store near by and now purchased set of best on the market Philips Ultinon Extreme H1 which Will go in anotjer set of projectors (I have 2 per side) and can't wait to put them on. In the mean time my remote key unlocks all Doors but not the driver ones and can't lock any of them and Windows started uncontrolably going down and up. I changed key battery-no effect. Is it engine lock or that Windows controler in door handle. It can unlock doors,except driver one but can't lock them at all and that red light on door is constantly on. Any help??? I Searched ETKA and there is green and black engine-must be phisycally checked-what means destroying all sound proofing of the door just to see which one I have, and I wonted to purchase it immediatelly so I can repair sound proofing instantly after engine replacement.
I was sure I Will built stroked forged 1.8T first but Here is how I Progress with B18A All motor NA NON VTEC bored to 2.0l. for my CRV RD1 New complete engine is ordered from https://www.pprmotorsport.org/ I bought B18A block due to his better and stronger construction than B20. Plan is all motor NA 2.0l NON VTEC, rev limit 9900rpm Stroke Will remain the same but bore 84mm Block and head are soda blasted,and head is already CNC ported and hand finished. Moroso oil Pan. Moroso oil Pan stud kit Red washers for oil Pan stud kit Felpro oil Pan gasket Felpro exhaust gasket port matched to cnced head ports Golden eagle main griddle kit with GSR tray,oil Pick up, dovel pins and ARP studs, OEM crnak stroke 89 lightened (on inner radius to retain rotarional mass-torque) micropolished, Custom vanadium X type rods rifle drilled Custom 84mm pistons CR 13,2, with Center hole for ignition Wet sleeves, Block guard, Ported oil pump Vanadium head bolts LS NON VTEC head ported polished BC stage 3 NA cams Adjustable cam gears Custom Springs Custom vanadium retainers Supertech valve seals Supertech bronse valve guides Titanium coated 1.5mm oversized valves, thermal intake gasket, billet intake, port matched to jead TB 80mm,-port matched to intake thermal TB gasket, thermal MAP gasket Billet thermostat housing Mishimoto low temp thermostat Mishimoto low temp fan switch Nissan GTR R35 injectors, billet fuel Rail, AEM FPR, STI Street super damper, Competition clutch stage 3, Conpetition clutch single mass light steel flywheel
Had misfire error codes and after replacing MAF,Sparks and Lambda still present. Only thing remained was FPR and fuel pump. Looking at fuel pressure gauge when applying pressure to the FPR we figured out at www.rsrmotorsport.com (only one who decoded OEM ecu for new RS3 in the world!!!!) pump is not following it. It was Lamborghini Galardo (the same as on LCR) 8L0 919 051H 4 bar pump. So I ordered used good one. Can't wait to replace it because I was lean on full throttle above 4-5trpm
