Everything posted by davojuri
- New Croatian VRS 236hp 19inches
Had to replace old TRW right rear caliper because it was producing squeling sounds when in reverse than also in forward driving-blocking the wheel-piston rubber went off. I bought this time Essen red ones,not green as last time but anyway I had to machine them again due to the new stupid wheel design-lack od space (with old 19s didn't have that problem). Painted that machined part in Foliatec 3020 Porsche Brembo red and now enyoing sound free new caliper
My friend Loctite is for sure one option. I just found here at page 12 that I already have custom made reinforced that part so I asked my friend in ΔaΔak, Serbia MiΕ‘ko Herc tuner to make new one with longer bolts, that's the proper way of instaling it in my honest opinion. Will keep you upfated
So first impressions are great. 1. engine and transmission mount from VibraTechnics is top, no NVH increase 2. KV top hats are far better than old one - no doing doing sound by wheel turning - no noise over every bump or hole in the road-simply can't believe 3. Flywheel was resurfaced and factory step 12,09mm retained -needed for SPEC clutches, otherwise 15,5 or 12.6mm for OEM or Sachs, and works so smooths ans soft pedal feel-now needs 500miles for break in than planned break in for brakes according to EBC protocol for Blue stuff NDX, 4. we worked a little on rear right brake caliper-was stopping wheel from backward rotation-squeling sound-its gone. So now I can take final pics of my black mamba and advertise it for selling if there will be a good buyer. lets see. In the mean time DSP Hertz amplifier final tuning this saturday. have a nice day guys.- New Croatian VRS 236hp 19inches
Removed old wire from Xenon balasts, water pump and water thermostat. Still need to put on engine Mount, to see why is right rear (passenger) calipers blocking that wheel from spinning naclward-onnthenroad making squezing sound, they were new Ate and painted red-hope tonsoΔve that, no more oil letaka whis was notnfrom the rear main Seal,or that gearbox sleve but were driven by thensir from blocknbreather adapter (Crestion motorsport one with 2 o rings) so we used OEM WV sealant to eliminate it and we did it, but I am planing to bore that adapter to a larger inner hole diameter, because it is funny small compared to AN10 adapter on it-and thus not fully functionalπππ And for the end some magnets for the reg plate mount.- New Croatian VRS 236hp 19inches
As always I must change things. Two black bolts are 12.9, because from old ones 8.8 one broken at grad during dismantling , VibraTechnics did put all 8.8, I bought more 12.9 black ones and 10.9 with 10.9nut for center ones M12 to reinforce it a little. Want to put all 12 9 but black nitrited Bolt with Chromed nut will corode, so probably 10.9 nut and bolt πππ- New Croatian VRS 236hp 19inches
We tried to measure pressure plate clamp force. Assembled it has 3mm travel and after first mm we exceeded Max measurement of 1000kg at that small machine. That day he recieved direct torque wrench for 1000Nm but didn't have time to make connection for it. So as I Said SPEC stage 3+ is by far strongest clutch with full faced springed friction disc on the market, 498ft lbs or 675Nm app. No one even close. And most important is OEM pedal feel. I've had it for almost 15y and shortly switched to Sachs performance and will never buy it again,that's why I returned to old good SPEC! We measured flywheel and it has 5050g-great daily driveability.- New Croatian VRS 236hp 19inches
Had time to clean my powdercoated subframe with 42DD solid mounts,Neuspeed tie bar and sway bar, TT LCAs, brake ducts from TTRS, and custom made shorter tie rod from 7075 aluninium, HR RSS clubsport coils with New KW top mounts. Hope to get rod od that doing doing sound from old Ground Control while turning the wheel.- New Croatian VRS 236hp 19inches
