skoda1982
Everything posted by skoda1982
  1. The BY21 has the New Modified Engine does not come with a engine cover its the same layout as the New Octavia coil packs are water tight here is some pictures of my November 2019 1.0l sel the coil packs are still exposed even with the cover. Plus 12 volt socket and torch.
  2. The BY21 has the New Modified Engine does not come with a engine cover its the same layout as the New Octavia coil packs are water tight
  3. I have read somewhere you can’t replace fitted for life whatever that means
  4. Probably coming in through the light cluster
  5. skoda1982 replied to Heat's topic in Škoda Kamiq
    No
  6. My Kamiq came with on but mine is build year19/20
  7. Build year 21 you don't get a torch so no one has nicked it. When you get the torch there is nowhere you can charge it as there's nowhere you can put it so it will be useless. It doesn't come in a bag as it is already in its holder/charger
  8. Will only update if it needs to be. If that's the latest it won't. Go to software update on your bolero press update it will check
  9. skoda1982 posted a topic in Skoda Enyaq
    From Wednesday 10th March youcan place orders for the Enyaq 60 priced at £30.000
  10. In the uk you can get the Kamiq SUV with a 1.5 TSI
  11. Does not matter where you bought your Kamiq from you can take it to any skoda dealer for service warranty work or any problems
  12. The all new Fabia is out in the autumn. What hidden extras
  13. go for the 110 sel worth the extra
  14. Your adblue tank holds 12lts a warning will activate when you have 1500 miles or 2400km left to run plus an amount from min to max you need to fill so you should have plenty of time to fill Checking the level Have you tried CAR menu on your informant Driving data look for the pouring bottle
  15. Have you registered with skoda-connect.com. If the globe is gray you need to register at skoda-connect.com. for Internet. if you bought the car new its free for 1 year if not its £44. Esim is free for 10 years but only for ecall and proactive service Active 11/21/2029 Proactive service Service Scheduling, Breakdown Call, Info Call, Automatic Accident Notification. This is what Esim is nothing to do with the Internet . But you still need a licence for Internet. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.skoda.co.uk/owners/skoda-connect&ved=2ahUKEwj5uYXsxtruAhWklFwKHSpOD64QFjAAegQIARAB&usg=AOvVaw0n1bZXnCOGADSWwIaoBKRk&cshid=1612797611586 This link tells all with videos
  16. If you could the price for upgrade you might as well have bought the SEL
  17. Cruise control only works when you are driving you set to the speed you want if you stop it keeps your last set speed. It won't let you set when stationary
  18. Turn your ignition on without the engine running for 1 minute turn off should have updated Dear ŠKODA Connect User, http://content.xcampaign.ch/gallery/3ZsaeGEG1BQwQuKQGF/1-1.gif ŠKODA Auto is constantly improving and simplifying our services. We would like to inform you about a planned maintenance which will cause the unavailability of ŠKODA Connect services for Scala or Kamiq model lines starting from 20.00 26th January to 8.00 27th January. To have all your data updated (in App and Portal) after the maintenance is completed, you will need to switch on the ignition of your vehicle for at least one minute, and then switch it off. We would like to apologize to you for the inconvenience caused by this temporary outage. Thank you for your understanding. Thank you for being a valued ŠKODA Connect user. ŠKODA Connect Team http://content.xcampaign.ch/gallery/3ZsaeGEG1BQwQuKQGF/1-1.gif http://content.xcampaign.ch/gallery/3ZsaeGEG1BQwQuKQGF/1-1.gif
  19. Mine works all the time never had a problem first year was free then I paid £44 for connect so maps and software can update and use real-time traffic. Laura online but did not renew myskoda £33 don't see the point in locking and unlocking the car remotely. honk and flash so you can find it in a carpark. user manual
  20. When you fit your bumper you will have to have the Radar calabrated around £300/400. Why not go through insurance. Don't forget to tell your insurance that you have had a bump even though you are not claiming
  21. Honk and flash unlocking door's the door's feature has to be setup by skoda dealer your driving licence is needed are done by Myskoda app. Have you gone into user's in settings. Was you the first owner from new. If not someone else could have registered with skoda-connect.com in which case you will have to pay for a new licence . All else fails all Skoda dealers now have tech people just for setting up connect
  22. If your profile is active then you are primary user. When you start the car does it say your name then you press ok
  23. Dear ŠKODA Connect User, http://content.xcampaign.ch/gallery/3ZsaeGEG1BQwQuKQGF/1-1.gif ŠKODA Auto is constantly improving and simplifying our services. We would like to inform you about a planned maintenance which will cause the unavailability of ŠKODA Connect services for Scala or Kamiq model lines starting from 20.00 26th January to 8.00 27th January. To have all your data updated (in App and Portal) after the maintenance is completed, you will need to switch on the ignition of your vehicle for at least one minute, and then switch it off. We would like to apologize to you for the inconvenience caused by this temporary outage. Thank you for your understanding. Thank you for being a valued ŠKODA Connect user. ŠKODA Connect Team http://content.xcampaign.ch/gallery/3ZsaeGEG1BQwQuKQGF/1-1.gif http://content.xcampaign.ch/gallery/3ZsaeGEG1BQwQuKQGF/1-1.gif
  24. There was an update for the scala and Kamiq between 8am and 8pm on the 26th January. For the update to work turn ignition on don't start the engine don't press the clutch pedal. Keep ignition on for 1 minute then turn off. Start as normal update done. That's probably why you couldn't register
