skoda1982
Everything posted by skoda1982
  1. I just leave heater in auto and just turn heater temp up and down using the knobs. If i need aircon i just press max button on off aircon stays on. the only time i go into menu is to turn aircon off which is just like turning the radio channels. I think lane assist is good only comes on at 37mph great on motorways its not a jolt on the steering wheel more than a gesture.
  2. text or phone message
  3. You can set it if you want it to find another station if the signal is low on the station you are on
  4. They do if you want to demist the windows press max button if you want to stop press again aim your vent at the window. And auto does not demist windows it keeps the set temp
  5. Manchester Birmingham and back 70mph and 50 in road works
  6. This was the same day first pic was to fill up and pick passengers. second pic was when i got back was about 64 drove a couple of miles to fill up again mpg dropped
  7. Is that all my kamiq I get this 1.0l manual
  8. Never had a problem with any. share my position for it not to come on only shares with skoda so they know where you are if you brake down and if your car gets pinched in settings click if you want to share or not. lane assist would not put you in a dich there are two sides to a road senses white line gently turns to left senses curb or white line turns you back, Leave Heating in Auto then set temp. i cannot find any fine tune. skoda connect i click welcome ok off i go
  9. never experienced rain below freezing so no water in the doors
  10. Mine collect water if I park on a slight down hill gradient as the drain holes are rear and middle none at the front. Got my kamiq last November and not a single problem with freezing water inside the doors
  11. skoda1982 replied to jez1404's topic in Škoda Scala
    Another one, if the outside temp gets to 4 deg it beeps if it gets to 4,5 deg on your trip then back to 4 it will beep
  12. The Kamiq Does have leather, heated windscreen, soft touch dashboard, electric seats set by user profile, An all new up to date chassis all new brakes suspension electronics and driver aids
  13. Make Shure you do a skoda scala configurator on skoda website just to make sure it has what you need and not what you thought it came with
  14. yes you could have asked the dealer as they give them free they did with me or look at Kamiq accessories, or buy online FITS YOUR SKODA USB Type-C to USB Type-A Adapter Connector £9.00
  15. So Skoda should update all EU countries including UK. so hopefully should get a recall
  16. If you have no Build week you can change your order
  17. The answer is No its not a dealer error They come with that size Space saver that is the size of tyre mine is the same you only use them to go and get your tyre sorted not to run all the time
  18. Hi here are some service intervals if you need them Timing Belt 210000 km Brake Fluid 3 year Air Filter 90000 km Air Filter 6 years Spark Plug 60000 km Spark Plug 4 years Oil Change & Engine Filter 15000 km Oil Change & Engine Filter 1 years Interior Filter 60000 km Interior Filter 2 years
  19. Do you want to change the spark plugs the service interval is 60000 km
  20. skoda1982 replied to jez1404's topic in Škoda Scala
    could be you front assist that has a loud beep keep your radar clean any road dirt can impair. And you can set the sensitivity from Early Normal and Late. Mine used to go off all the time till i set to Late
  21. skoda1982 replied to a post in a topic in Škoda Kamiq
    Might be virtual display settings see if in classic view and not one that you can set yourself then use view button on steering wheel
