Everything posted by tuningmania
message on dash how to re set it
To @Kevgem - https://youtu.be/kIOdyDV3obg
MkII diesel 2009 model rear differential oil change
To @Attis1974 - OK There are few other oils that is good to be changed under the Car. Be careful with "Skoda"-Dealers. They often told that some of this oils do not need to be changed which is not the best for the Car.
To @J.R. - I own few different "Skoda" Cars from about 15 Years and from about this time I read regularly few different "Skoda"-Forums and my recommendations are consequence of all information that I read and remember
To @Attis1974 - I recommend only "OEM"-Oil for differential. You need one bottle for rear differential. Did you change other oils?
Passenger footwell light
To @Bleechy - Be careful with cable only. There is nothing other to broke. Push hard. P.S. There is clips but there is no way to broke them I think..
To @Bleechy - I think that a man with more strong hands than usual can push it down. It is all about force
To @Bleechy - It is awful to remove it. I think no tool can help. Only hard hands. I have blood on my fingers from forcing. After more than an year - what is the reason to be produced so hard is still unknown for me. I push hardly from the back - where is the cables..
Superb mk2 multimedia upgrade
To @ramunas - Check this two brands: "Witson" and "Erisin".
Android head unit recommendation for Superb
To "EVERYBODY" - After "Copy"=>"Paste" technical information that @JORDITO give us in www . google . com in the first few results is the official web site of "Witson" brand. Check it.
To @superbdreams - My unit was recommended and installed by @JORDITO and I do not know the brand or model :( I can not find brand or model in menu of the unit and on the box. Ask @JORDITO. The "Air Bag" warning light is not disconnected but stayed behind the Head Unit :(
Change of Automatic box fluid
To @BobH38 - Change the "DSG"-Oil. 7 Years is long time for one oil..
Skoda Superb 2012 Mk2 KESSY driver side stopped working
To @Thorn - I have some Problems with my "Kessy". Sometimes work OK, sometimes not. I change the key battery and everything is OK
Columbus Sound System
To @PeeMac - I am not sure if this help but when I change my Audio/Video Head Unit I have no sound too and here in this Forum I found a solution - disconnect the car battery for 30 Minutes and then connect again and my sound appears
Skoda MkII Kessy and Fuel tank flap lock issues
To @chimaera - When the Problem with fuel cap appear for the first time on my Car, I try to press gently fuel cap after I unlock the Car but fuel cap stays locked. I try again and again in the same way and the fuel cap opens on 5th or 10th attempt. I use this method few months before I realize that there is no logic when the fuel cap opens. After that I start to gently press the fuel cap only when the Car is fully locked, without lock/unlock and by this method the fuel cap opens every time
To @blood - I have no Problem with "Kessy" but the fuel cap randomly stays locked when unlock the Car. This is known Problem with fuel cap lock mechanism. It need to be changed with the new one. I find that, on locked Car if I press few times gently on the fuel cap where exact is the lock mechanism, this lock mechanism moves few Milimeters on every press and after that when I unlock the Car the fuel cap opens normally. But this is short-term solution..
Estate Electric Tailgate Struts
To @geno101 - The electric tailgate is an extra option. There is the same model of Car, that is manufactured with gas struts and the open of the tailgate is like any other Car
Help with Thermostat - Not getting up to temperature - Proving a faulty thermostat.
To @softscoop - 99% of this Problem was caused by faulty "DSG"-Thermostat. Change it without doubt
RECALL
To @Kevgem - Many people refuse to get "Diesel Emissions" update because this update have negative effects to "EGR" and "DPF".
Superb Electric Tailgate Struts
To @StephenFoster - I have no massage :(
To @StephenFoster - Please, share the link from www . ebay . com..
no sound from swapped radio
To @gullible - I change my sound unit and the new one have no sound at all. Disconnect the car battery for about 30 Minutes and when connect back the sound is now working great I am not sure if the situation is the same but You do not lose nothing
New to Superb II FL from Octavia III - is this normal?
To @mikemanpl - My thoughts: 1. It is normal; 2. It is the same on my "Superb" too and I think that this is not handy; 3. It is normal, clutches do not like low rpm..
