Tech1e
Honorary
Everything posted by Tech1e
  1. The brake pedal wire is just a 12v ignition feed.
  2. The diagram looks fine for that wiring kit to me.
  3. For those who have been around a bit may remember my DIY camper build: Well I used that for a fair few years then as life changes it wasn't getting used as much, so I sold it (tidy profit). Fast forward a few years, Covid, divorce, relocation and I felt like the camping itch was back. So after discussing with my partner we decided to have a look about. And this is the result.. No self build this time, shooting for a built one. Needs a little 'modernization' as a lot of campers/caravans do, but it has all the things we need. Rock'n'roll bed, fridge, sink, oven, storage a plenty. Clever use of space being a short wheel base, but fine for the two of us and the doggo. A good scrub up, some new curtains, and maybe get the furnishings re-upholstered and I'll be more than happy.
  4. s k o d a t e c h i e @ g m a i l . c o m
  5. I might be able to do a Sunday, my workshop is in Powick near Worcester.
  6. It’s kind of a yes and no answer. Yes is is possible, I have retro fitted many MK2 Fabias with cruise control. But Skoda have now discontinued the kit. The one I have in stock is the last one they made.
  7. 100% either t11a or t11b, they all have the white wire to the ECU.
  8. I'll be honest I hadn't read your reply, I just said what needed connecting. You are correct, the pedal connection is merely borrowing the ignition live. Can just as easily come from the fuse box, from pin 2 of the headlight switch, or from the relay board. Whatever is easiest for the installer.
  9. On the Kufatec harness the 10 pin connector goes to the switch, the 6 pin connector goes to XS3 on the central electrics control unit, the female terminal goes to the fuse box (ignition supply), and the male terminal is the connection to the ECU, that goes up to the bulkhead connection point.
  10. MK2 Fabia vRS cruise control is £350 supplied and fitted.
  11. £180 supplied and fitted at my workshop near Worcester.
  12. www.astra-sport.co.uk as it was.
  13. I am indeed The seats etc are the same in principal, they go together in much the same way.
  14. No need to be sorry, I was genuinely interested to see if you had it done by a dealer is all.
  15. Gave to old girl a birthday clean this weekend. 20 years old and still slaying the Mustangs.
  16. Did you get it fitted by the main dealer in the end? Everything go OK? I would assume it did.
  17. https://www.ebay.co.uk/itm/Skoda-Fabia-MK1-Radio-Cover-Top-Fascia-dashboard-VRS-DIN-Surround-Adapter-/115249078060?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
  18. not exactly far. Chap came from Belgium a little while ago lol
  19. factory shafts from Ibiza FR, Polo GTI.
  20. yes you will have to widen the bracket.
  21. Ah that’s why then. The Octavia uses an 02J and the Fabia an 02R. The 02J is wider at the end case where the mounting goes.
