Macdemon
  1. Don't go Expatman, you can still be part of the forum here and I'm sure I speak for everyone here in saying you're correct, the Yeti was just THE BEST.
  2. You need to do a new search for DAB stations and then pick it from the updated list, it won't add it automatically.
  3. You should be able to add stations by selecting the 'favourites' button indicated by a star. And the infotainment system should remember then whenever you start the car again. It's just a case of sitting in the car and 'playing about with things' until you can work out how the system works. That's what I did.
  4. Hi Genesis Which EV home charger do you have please? I'm with OE too and on the same tariff as you.
  5. I’m having lots of issues with my Ohme charger I had fitted at the end of Jan ‘24. it is constantly going offline and not charging my Octavia hybrid. Does this sound familiar??!
  6. I use 'Granny charging' at home as I have not yet invested in a home charging point. I want to get Christmas over with then will invest in one. A 3 pin plug will change an EV but very slowly, thats why a charge point is quicker but not much as the Skodas and many others charge at a silly low rate for some reason, maybe its to keep the batteries in 'tiptop' condition. Constant rapid charging do not do rechargeable batteries any good, a slower charge is always better. Hope this helps. Oh, anf I can charge to 100% when full.
  7. Macdemon replied to Dallsy's topic in Skoda Enyaq
    Have you contacted Ovo to see if they can help?
  8. Thanks toot, I'll go and have a look. 😀
  9. I've just put a deposit on a nearly new Octavia from my local Skoda dealership.............it's a 1.5 TSi iV DSG. As this is the first time I've dipped my toe in the EV automarket, I was wondering if someone might know the answers to a couple of questions I have. 1. I want to invest in a 7Kw wall mounted charger, what are the advantages/disadvantages of tethered chargers with untethered chargers?? 2. Should I get a charger with an earth rod or one without? Again........pros and cons of each option. Thanks for reading this. Macdemon
  10. At what sort of speeds does problem manifest itself?
  11. WOW!!!!!!
  12. WOW..........thats impressive to say the least. Good result there Jordan.
  13. WOW......its good to have a healthy, friendly discussion sometimes. Ive just filled up and had an improvement on my MPG in the first posting.............
