varooom
Everything posted by varooom
  1. Sorry I don't think I have one that matches that SW Train.
  2. Maybe I don't think it will matter too much myself, but would be a pain to remove this small pieces of glass (if your beam pattern is ok, I would not worry) It may have happened at same time or before, replace and test Replace BOTH sides at same time, and make sure to not touch any of the glass as this creates hot spots that can cause these failures. Only exception to changing both sides, is if you not that long ago swapped the other side. If you only swap the one bulb, then you will see light output and a colour shift from one side to the other, As written on the bottom you need D3S bulb of course. You will then have a single spare bulb for testing. or if one fails on the road.
  3. Yes and Yes Incoming PM...
  4. MEN3_EU_SK370_P0113P MU 0469 I can send you this by Private Message
  5. Sent in another thread for you, best of luck.
  6. Need to write in English please in forum. I will send you link to 8755 version by private message.
  7. Currently for user @Lennart his OCU module is not happy, as it seems to have a parasitic drain. Hopefully he will post here or update his post with any possible new information. I would recommend you wait until he has seen the posts above and, he will be able to advise you if you should attempt this at home.
  8. Maybe, but won't know unless you provide details of the Software Train.
  9. Take a read of this post, https://www.briskoda.net/forums/topic/512288-update-my-car-from-0156-to-0306/ I have the files, but if you update, you will loose activation codes for Sat Nav. This update is dealer only, as you need to program in new codes for functions.
  10. You are correct, SD Card needed. I will send you some instructions with link.
  11. You have a MIB1 System (1st generation) MIB2 is 2nd generation and as mentioned by @pab567 can support Android Auto/Apple CarPlay for he is the hardware expert 🤝
  12. 0490 - 0407 = 83 (a bad joke was made!) Easy to install, and take 20-40 mins roughly. That would be 6, anyhow jokes aside there is no changelog provided, so mainly stability and bug fixes are what are applied... usually you don't get new added features with update. MIB1 System, and I will send you link & instructions in a few moments.
  13. There is an update to 0490 version, and I think it will add +83. They don't give changelogs with firmware updates directly, so you have to read TPI documents for vague clues.
  14. @pab567 This sounds like a hardware fault, recently updated to 0490 version and still errors. Maybe swap to a MIB2 unit?
  15. @batgruyo I will send you a link to 0480 version
  16. Yes, I will send you a PM with link
  17. I sent it to you by Private Message, maybe you missed notification (top right usually)
  18. Why aim so low, you can have MEN2_EU_SKGPx_P0080L with versiob 8755!
  19. Thank's Pete, it was something like that, but too tired to think straight 😁
  20. Make sure to also check VW Polo's (93N?) of same age, they share same part number. Good luck with your hunt.
  21. 0480 version is the latest available, I guess you would like a copy of that also!
  22. You will soon have silence, I will PM you link in a few moments.
  23. If you buy a battery from Tanya, let's say £140 delivered, then chuck someone off VCDS say £20 for adapting, then you are saving lots compared to dealer mad prices. Comment was also to show that your mechanic might need to see those documents and learn from them, this is a simple process. Best of luck with whatever route you go with.
