Everything posted by varooom
Changing a s/s battery?
This is what is involved
Software Update available for Bolero?
Private message sent
Amundsen MIB2 Firmware Update
They are OK AFAIK. But the site is slow like ancient dialup Internet.
Is there an update to Infotainment System (5Q0035842A / H24) newer than 0241?
Yes you can load 0253, sent via private message.
Latest Infotainment version Bolero
You need to narrow this request down, press and hold Menu/Setup button for 10 seconds, then you should be in engineering mode. Look around menus for Software Train, take down these values or a picture. I cannot do anything until you bring this information.
Infotainment Model Numbers
You can update to 0480, but don't expect it to magic things to appear. It cannot add Nav to a unit that does not even have Nav button and all the physical parts missing.
Columbus update problem
Does seem that the codes have left the system, you need a dealer or possibly an independant workshop with online access. It then in theory can feed in the codes needed to re-activate the factory issued codes.
Forgot to say, did experiment before about formatting of cards, the free space on an SD Card will vary depending on format used IIRC "exFAT" gave more free space than "FAT32" or "NTFS"
You maybe able to remove a language from the package, if not you might need a slightly different manufacturer card?
Have you tried a factory reset? Next could be a fault in GPS aerial/wiring (can you see any satellite detail?)
Hopefully he will reply soon, I have firmware here for when you need to load it.
The update is your decision, I can provide file and some instructions.
This is not normal behaviour, these should work regardless of map updates. You have either a software fault or a hardware fault in your system, so the firmware update could rule out a bad software.
Skoda won't send you a firmware on that web portal. The above named file is available from me if you want, and you can see the update is support on your radio via the SupportedTrains tab Let me know if you want me to PM you a link and some instructions. release = "MHI2_ER_SKG11_K3343" MUVersion = "1433" <SNIP> SupportedTrains = "MHI2_ER_SKG11_P2104*,MHI2_ER_SKG11_S2104*,MHI2_ER_SKG11_K2129*,MHI2_ER_SKG11_S2129*,MHI2_ER_SKG11_P3260*,MHI2_ER_SKG11_P3304*,MHI2_ER_SKG11_P3325*,MHI2_ER_SKG11_K3330*,MHI2_ER_SKG11_K3333*,MHI2_ER_SKG11_K3343*"
@Serialski If you have carplay activation by factory/dealer then it will be available after the update. If you updated by other means, then you will need to apply patch again. I think you will also be stuck using USB for phone link, and Wireless will not work. And I recommend you stick with the 0369 update I will send you, forget about swapping to 04xx version.
Sd Card to small for the new update
If they faked the CID - Card ID for Skoda/SEAT/VW then the system won't know and it will pass "security" and load.
Infotainment rebooting randomly
I have sent you a link to 0480 firmware, it might help. It will rule out a hardware fault.
Update MEN2_EU_SKGPx_P7130L
Most likely this is the fault code B201A
Columbus mib1 several problems
I shall send you a link to update this to 0412
Update sent by PM
newbie
That's doing a "Blue Peter" "here's one I made earlier" 😉
From me, main post here for detail
Updating Swing radio software
Sorry cannot find an update for that Software Train.
Columbus mib1 0409 firmware
@pab567 this sounds like hardware, and you will probably know the answer.
You have a PM to read from your other post, good luck with update.
