varooom
Everything posted by varooom
  1. @Perguizas @Ruddi @HellB0yIRL @SparkieMark You shall all have PM's with link to download.
  2. The firmware is EU region locked, so nearly all regions are supported. So will Contain many languages inside. You can update to 0369, and the swines don't provide a changelog per se.
  3. 1. Not sure, other than it's MIB3 2. Yes your diagnostic SW is correct, version 0306 is available 3. Not enough detail 4. Could be expensive to swap for little benefit (and the infotainment system is tied into other car systems) So you could update SW, but do so at own risk.
  4. Press and hold the Menu/Setup button for about 10 seconds.
  5. @pab567would be the best person to answer a HW question. Please be patient he may reply sometime tomorrow when free.
  6. Sounds like your HW is broken @hmmt
  7. Yes reach out by private message
  8. I have sent you a PM, let's hope that you are "MHI2_ER_SKG11...." as stated
  9. Yes you can update, VAG don't supply changelog, so one can assume bug fixes (not adding features)
  10. I shall PM some instructions to assist.
  11. Also @Djadjo78 same message... Yes you can activate for "free" but you need to have VCDS or similar tool to enable "Developer" mode on radio. If you have access to these tools, I can talk you through process by PM.
  12. @Djadjo78 @katanasan0 Check your PM's
  13. Did I miss sending this to you? Sent as requested, best of luck
  14. Yes to 8755, this cures the crackling noises.
  15. Yes to 0480 version, will PM you a link
  16. Yes, to 0480, I presume you want it, so will send you along a copy.
  17. @WRumbled MHI2_ER_SKG11_K3343 Version 1433 is available, will send shortly.
  18. There's and update to 0480 I can send and you try it.
  19. PM link, and you to load onto SD Card
  20. SW Train: MEN2_EU_SKGPx_P0080L MU: 8755 I can tell you that this FW is available, and most install it for issues with Apple playback. Someone might be able to assist with the other questions.
  21. That can update to 0306 version.
  22. I will send you update to 0490 version.
  23. Yes to 0253, sent via PM in a moment
  24. 0138 is the current version for the 01xx SW Train I will send you 0138 version
