varooom
Everything posted by varooom
  1. Press and hold down your Menu or Setup button for 10 seconds, to then enter the hidden engineering menu, and then please take picture of your Software Train. I suspect I know the value, but I would rather see to be sure.
  2. Post a VIN, or send a PM if you wish. Not sure I can get you information, but will take a look.
  3. I will unpack/pack you then my file. Probably 20 minutes of work.
  4. Ignore the 015E/017E numbers... you might have more luck using the the fact it's a Hella headlamp with part number 1ZS 247 047-11. Also scrapper will be your best bet, should be plenty around to find a part eventually. But as mentioned by @softscoop do some drying/investigation work, we all know water and electric are not the best "friends" Also, you can bypass mad dealer rates, and learn how to drop bumper off, first time is always fun, and better with a partner (joke there...) it becomes quicker to do once you know how it all comes together, and worth seeing if you need more parts around headlamp area that might be broken. As for the dealer calibration, you can most likely do this yourself with VCDS tool or equivalent, plenty of people in West Yorkshire can help out with those (me included)
  5. I am 99% sure it will be PWY24W, the other can be one of those little brain flips where a letter gets swapped (then it takes a few copy/paste errors to spread)
  6. Install Free Download Manager and intergrate this into your browser. It will then capture download link and speed it up. Try speed and report back, otherwise I can supply if needed.
  7. Firmware is any card. Maps have to live on say a Skoda SD Card, and then it needs to stay in the car 24/7. eBay or Amazon might have fakes, so make sure you have PayPal protection or fight Amazon.
  8. Blame the schools, every kid on sports day is a winner right 🤩
  9. TPS can be shirty dealing with the public, not every branch, but ymmv as they say. Best of luck, post back if you get stuck in finding small parts, someone might be able to assist.
  10. Both numbers are for RHD because the 3rd character is a 2 not a 1 for LHD. But your B part is a typo, as not seen by me in catalog. I presume you have NS (Passenger) headlight issue? Can you state or show image if appropriate of what is wrong... dealers can ream you out for a new part when it's a simple fix.
  11. I can raise 0 posts in 12 years, so I win top trumps I think, what does our adjudicator @Gaz think?
  12. Have a gander at the online catalog, might take a bit of getting used to, the part might be in the "body" section https://www.lllparts.co.uk/catalogs/skoda/CZ
  13. I can reply here for you, the missing NAV SD Card is not a big issue (some hate the mapping, and use alternatives) If you do want maps, then you need a "VAG" SD Card (Skoda/Seat/VW) and the forum has instrutions and downloads. So let us know if you wish this, and we can aim you in the right direction. I will send you 0253 update as mentioned before, same version I am running on own car. @pab567I will send firmware, and thank you for anwering the Canton question, I wanted to make sure there was no hidden surprises in doing the update (I seem to recall Audi I think would say not to update the amplifier, but nobody ever said why)
  14. Damn, he probably loads firmware, then sends it out the door. Rinse, repeat. This with the DPF issue (hopefully making progress on that?) Not good.
  15. The thought had crossed my mind beforehand 😁
  16. Looks good, hopefully you can clear up the niggles soon.
  17. It will probably be some kind of "leisure" battery or some suchlike name for it. Definitely exists on parts catalog and workshop manuals. Not sure why the OP is asking for the dimensions yet.
  18. You can update to 0253 version, as long as the smoke remains in the boot afterwards, you should be OK. @pab567 Can you see any potential issues with updating software with Canton installed?
  19. Sorry no idea on dimensions, (and they don't even list part number for a battery that could be cross referenced) A part number of 5L6 801 287 - Four-wheel drive 5L6 801 287 A - Front-wheel drive Is as much as I can locate https://www.lllparts.co.uk/catalogs/skoda/CZ Illustration should be 803-050 (8 being Body) when you look You didn't add any details on year to your post, or why you need the dimension (curious on the latter)
  20. I would stick with these numbers only, if it was my car. That colour you posted could be a different shade, and stick out like a sore thumb.... those paints are not too expensive, and cheaper than a mistake.
  21. I am not sure updating your software will make things just work I'm afraid. I can send along the update and you can try of course. Any factory stored FEC activated codes should remain afterwards.
  22. The tl;dr is that if you drop in a same technology battery of a very similar Ah rating, then forget about adapting the battery. So you can still buy a SS car if needed.
  23. This comes up for Octavia 2016 (G) 9P9P - F9E I found Candy white on a Golf as this though. 9021 - B9A But that doesn't match any numbers you have given on your list, so no idea why you dealer is choosing that. If you want a touch up pen set, then you would order 3T0 050 300 F9E For spray cans 3T0 050 200 F9E How it works if you may buy a part for your car (let's say a rear spoiler) and it might come painted. My car has 1Z1Z - F9R for Black magic pearl effect, so when I find the part, it will list F9R on the end of the part number to indicate a colour choice. Spoiler is 5E9 827 878 A, but it can be purchased ready painted, making the part number in full... 5E9 827 878 A F9R
  24. EDIT: It's for stop/start technology cars, if applicable then read on. Means this...
