Everything posted by GiscoYeti
Rattles and Creaks
Battery coding
Hi, you could use CarScanner to code the battery !!! see the code Vendor in RossTech forum if you have not BEM code
Kamiq MY20 MIB3 Update
Hi I recently made the switch on a friend of mine's Kamiq MY20 from SW 0156 to SW 0330 (156>>> 0238+0268+0278>>>0308>>>0330) after checking OCU from ver 088 updated to 0143. Thanks to this thread, it helped me a lot! We used a 32GB USB C formatted strictly in FAT 32 and dezipped files with 7Z.
Ambient lighting
Hi I have nalla Kamiq MY2020 the ambient, if you are in possession of a VCDS cable could you make of the 5F ECU the ADMAP as I would have to change the “suns” in the dim lights screen I would like to know the choices made in your montecarlo. Thanks
Yes: Open " ECU identifiers" and select controller 75 (Emergency Call....) or all and read, .... You see the version
Update MIB3 with old MOI3_EU_SKMQB_P1550P firmware
You need to read here: 1) 2) and here
SOS, Sat-Nav software query
Current software for HW 12 is SW 0330 installed and running, for HW 22 SW 0332, it is also important that OCU is at least at version 0139.
How to unlock MIB 3 Preh with patch...
Ciao Have you update the OCU? TPI-2060553-8.pdf
Hi. At the moment the patches stop at MIB 2.5 the 3 is still unknown and armoured, better to make the updates at least to version 330
OCU Update
Hi great news I could not find version 332 Mib3 Skoda is it possible to have the link also in pm Thank you
Can anyone identify this hose please?
Hello it is the petrol vapour recovery system with activated charcoal, the bottom tubes come from the tank the broken one from the intake manifold, it should not produce many vapours (injectors) but it would be advisable to change it to avoid problems
Lane assist camera
OCU Update
Hello I beg your pardon, I am also in possession of a VCDS cable and if possible could you please post the step to do for crash signal verification? My OCU is 0139 and I should upgrade to 0143 but I am waiting until I am clear. Thank you Gianfranco
Software Update Notifications - Dealer says ignore!
Hi as far as I know I have done two updates with USB (308-324)it is very likely that OTA happen by VIN, my Kamiq is MY20 (February) even though I had my system replaced and even though I installed SW0324 OTA update never seen, some of my friends with MY23 and SW0324 already got it. Thank you for your kind attention!! Gianfranco
Virtual cockpit plastic frame
OBD Adapter & Torque Behaviour
Hi only the latest generation OBD2 adapters, and also a bit expensive, go into power saving I don't think Torque has the procedure except for the Phone, better disconnect it from the car !!!
Hi the Kamiq of 2021 with SW324 and HW22 update SW OTA, I saw you had an update for traffic signals so you may have these requirements!!!
Hi the extension cable may not have the correct pinout, you should check the connections on the car side and OBD dongle
Armrest Height Extender Solution
OCU Update
Hi, the TPI I think is 2072245-5.pdf in Italian I attach the part about OCU 2. OCU ECU software update Before we start with the upgrade of the OCU ECU to SW 0143: - To upgrade to the new version SW 0143, first install SW 0088 in the OCU controller! If software 0083 is present in the OCU ECU, perform the upgrade according to task 91Y8 .
Driving in Europe with standard LED lights
OCU Update
Effectively the OCU is closely connected to the radio/navigation unit as it acts as a "link" to the FEC and SWAP purchased in the purchase of the car (factory pack) I specify that my system is Amundsen 5F=3V0 035 816
OCU Update
OCU Update
Hi,sorry to intervene,I have a Kamiq built in Jann 2020 and I post you the picture of my situation after TPI recall done in July 2020.
