freedie
Everything posted by freedie
  1. You could reset them to the temperatures you originally wanted! (Not as easy as I made it sound, though.)
  2. No. It is completely different.
  3. Or you could try resetting temps using this
  4. ...and good luck too.
  5. Right. I did realise you had tried everything. I have released the front screen wash and experienced the stalk clicking through to the rear wiper position; but... you have obviously taken everything into account (including the maxidot). So it now sounds like a mechanical fault with the wiring sensor in the the clockspring area. Good luck.
  6. This will happen if the wiper stalk is pushed away from the steering wheel to wash the rear screen and not pulled back after release. In other words it is now stuck in the "rear wiper on" position. Worth checking, as the motor must be OK if it moves as you describe!
  7. Have you inadvertently pressed the safety switch on the door panel for the electric windows?
  8. Yes my calculation using different prices (applicable here!) was 43.56 mpg, so as above...
  9. Erm, yes. But didn't we all know that already?
  10. There most certainly is. Sounds like a smoke alarm and scares the s s smoke outta ya! Works very well too.
  11. I think if you remove the sills the mud flaps WILL fit...
  12. Are the tyres different profiles?
  13. Wow! Hehe...
  14. I have the same sitting in my car waiting to be refitted. It has been there three years and all is still well..
  15. Small trapped stones do make noises like that. Reversing a long way at slow and mediums speeds may eject such. Good luck whatever.
  16. Not quite the same for me; but I remember a poster mentioning this and I went and and saw the same. It just cleared up after the next use (of the headlight, I mean) and that was seven years ago. It has not reappeared.
  17. freedie replied to awfabia's topic in Skoda Yeti
    Whatever you do, don't double the number of candles...
  18. As a friend says ~ "Crikey!"
  19. The lever will not move easily when the bonnet is at its widest (narrow) opening, if you follow my drift. Push it down slightly to better pull the lever. Good luck.
  20. Solution is lots of grease, and not just of the elbow variety...
  21. But if you want to lock the car, fold the mirrors in and leave the windows open (you might want so to do one day!) do what RickT says and then hold the open button until all the windows are open (the mirrors will stay folded) and then lock the car as normal. Phew!
  22. Likewise, please!
  23. Or to put it another way ~ definitely Muscovado !!
  24. Well I've got that unit in my first Yeti and all the things you want/wanted to do worked and still work. Let me know what help you need and I will try to suss it for you.
