Posts
68 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by dancool27
Air bag and limp mode! ARRRR!!
dancool27 replied to Sambo281081's topic in Skoda Octavia Mk I (1996-2004)
Did you ever solve you air bag issue as I have the same (passenger side airbag resistance too high) -
Got them off eBay they were ring drls had to trim the grills with a dremel to get them in
Well now she will soon be for sale as the other half's escorts will be cheaper for us to insure and we don't need two cars :-(
I'm at 314000 1.9tdi 90 ALH on its second clutch original turbo and gearbox
Mine were ring ones that I manged to snap up for £18 on eBay then fitted with a dremel
Only photos i have taken this morning. Excuse the dirt lol
Finally some pictures of Mk4 Golf interior. Pic of rear bench still to come And at last sorting out sub & amp And Mr. Postman brought me some goodies
Just replaced my blades. Aftermarket ones were crap. So went OEM
Engine cover got taken off today and engine had a good clean it was caked in crud as you could imagine after 313000 miles Nice and clean
It's nearer to 313500 now lol
Yes it was. 2 owners before me. Was regularly serviced by skoda up to 160000 miles then the next owner got it serviced at independent garages. But as far as we are all aware as I know the previous owners its on the origional suspension and origional gearbox. Everything works apart from the sticky rear wiper but I have a replacement motor on way
Hi I have a 1.9tdi ALH unit and looking for advice on removal and if I will get eml if I delete
Lol Yh there the ones. On removing egr does anything need to be done at ecu?
Now fitted strut brace and feels a lot better on cornering (many thanks to Gee-Man for supplying the brace great guy when he not injuring himself lol) Next me and my brother in law are making a sub enclosure to go in cubby hole on left in boot where cd changer used to be. Still have it and is surplus to requirements
Has anyone here done an upgrade on the injectors on the 90hp ALH engine. Mine is a 53 non pd engine What is involved and will ones from an 03 ASV 110 engine fit straight in?
Finally fitted my drl lights and w8 interior light
Might not have enough gas in my mechanic only put 600 in but sticker on slam panel says 750+50
Still very rarely getting cold air. , been unable to check how fast clutch spins at moment if it does is it easy to change been unable to check how fast clutch spins at moment if it does is it easy to change under pollen fiter seems fine it blows out air with good force
Seems to be intermitant. Turned off for 15-20 min while driving when turned back on it worked but then after leaving car for 20 min next time it was started it didn't work. Maybe where it hasn't been used in a while
I have a issue if you can help. Had my aircon recharged but only seem to get cold air on tickover. Clutch engages on compressor and fan goes. Although revs don't drop much when turned on Any ideas. Dan
Does anyone know if these would fit into the standard bumper as the look the same size. and where i may get some
Greek Octavia Presentation photos-mods
dancool27 replied to Paul-Greece's topic in Skoda Octavia Mk I (1996-2004)
Where did you get the dials? -
Nice too meet you too Gee-man. Hope your finger gets better soon so you can carry on with your build and thanks again
Thanks for all your help guys I feel like such an idiot. After tightening handbrake cable up all now seems fine no sticking and handbrake holds and releases. Just a novice error as have never done shoes before.
Ok cannot use car without wedges otherwise pedal sinks to floor even after pressure bleeding. Once wedges are back in brakes work great but still stick at rear without use of handbrake. I'm guessing that maybe I havent got them back together correctly
