Cleaning Filter on a CAI
Hello..
I have a EVOMS cold-air-intake on my Octy vRS... to be honest its sounding a bit asthmatic at the moment so i want to clean the filter... Now the filter is down in the wheelarch, hows the normal way to remove these? is it a bumper-off job? :confused:
and how can i clean it, i dont have any specific cleaning stuff (i used to just use fairy liquid on my old green filter)
Take of the wheel (You may get away without doing this), then undo about 9 of the torx screws holding the wheel arch liner, peel it back and you should have enough access HTH :thumbup:
Or do it from the top by removing the battery and take the intake off as a whole
Pretty much all of the manufactures of filters do a cleaning kit comprising of a cleaner and then a re oiling solution.
K&N's one is about a tenner i think
Undo the jubilee clip holding it to the MAF housing and stick the hose pipe down the CAI :P
squirt in some fairy.. bobs your uncle! :rofl:
Might have a slight problem... cant find my locking wheel key lol :rofl:
bash a 17mm socket over it or do it from the top problem solved :D
twerp.
:rofl:
I remove the wheel arch and use the k & n cleaning kit.
