Octy II Wishbone bush upgrade..
Spotted this over on SCN, one would presume it would apply to the Octy too.
Feel free to thank me ;)
Its interesting really because on 5th gear Tiffny dell said the octy steering was a tad more "wooly" than the GTI's... maybe this is why.
This upgrade is common on the Fabia vRSs and makes a huge difference :)
Normal Wishbone bushes top, vs LC/S3 bushes below.
Audi -
BHC & BZC Left - 1K0 199 231N
BHC & BZC Right - 1K0 199 232N
Skoda -
BWA Left - 1K0 199 231J
BWA Right - 1K0 199 232J
I must be missing something obvious - isnt it just the same mount but turned over?! :o
Lee
It seems to be a common theme Lee, the stiffer they want them the more rubber they put in. The upper one has two holes in and the lower doesn't.
Anybody got the seat part number for this as i have a friendly seat dealer.
SEAT number will be the same as the Audi one.
I'll get the number for the bush lube you will also need to push them on. Also you need the mounting bolts.
Change a fair few of these for squeaking noises (hence needing the lube)
i googled for this stuff at work and nearly ended up in trouble.......:eek:
Lee
i suspect one is a left hand mount and the other is a right hand mount
any ideas of prices for these?
