vibrations?
hello there these aint the good sort of vibrations lol these vibrations happen when my car on the move an get worse as car gets quicker. what could this be? gearbox perhaps
engine mountings?
wheels out of balance?
Mine seems to be the same oddly enough.
the steering wheel seems to be vibrating more than usual.
I think my wheel bearings on the rear need checking or replacing.
First i'm going to adjust my tyre pressures. It only seems to be happening more snce Kwik Fit put my spare wheel on due to concerns over one of my tyres.
front wheel bearings? Rears tend to just groan
well it seems to sound like reving evev when i take my foot off the accelratr . an it vibrates down through the pedals.
have you lost the vibration damper off the right hand drive shaft???
They put it on the front?
Get the wheel rebalanced. SHould fix it i'd imagine. Especially if it was ok before the wheels were switched.
:)Out of shape tyre, loose wheel bolts, wheel balance, driveshaft fault would be the things I'd be checking.:thumbup:
Do it QUICKLY though, as any of the above [except wheel balance] could be dangerous.
its comin from the engine as it sounds like some sort of rev? im takin it down my dads at the weekend he will hv a look at it:D
Why didn't you say that in the first place :rolleyes:
I still don't know though :D
