Power feed for bypass relay?
I have been trying to work out where to take a feed from to wire in a bypass relay for my towbar but havent had much success so far :o
I've searched for this and have found some threads but they seem to no longer have the links in for the pictures that I need to work out what is going on, I have take the glovebox out and found the gromet behing the panel at the base of the windscreen but I have no idea how i am supposed to get at the point where the gromet comes into the cabin? Does anyone have any pics of this or any advice on how I can get a permanent live feed for the relay? :)
Andy
Now you've got me worried. I was thinking about the same thing before buying a bar. I had thought I could simply take it from the 12v socket in the boot ( I have an estate) with an in-line fuse instead of having to route a wire to the front of the car.
Am I missing something obvious as to why this wouldn't work?
Stu, thanks for the link, i have had a read of those instructions but unfortunately as they are for the 'proper' Skoda wiring kit it only refers to "find the spare 12v spade in the fusebox" for the none-Skoda wiring, think I need to dig out my voltmeter and go spade hunting! :)
GreenMachine, I only have the hatch so no power outlet in the boot, I was wondering if the easiest place to patch into was the feed for the 12V socket, nice and easy to find and with separate inline fuse should be ok I would think (unless someone wants to warn me against it!?)
You should ideally go back to a source supply so as to be sure you have enough current supply, I'm assuming you want to charge batteries and power fridges etc - I don't think the ciggy lighter can take it.
As a rule you shouldn't connect a larger CSA (Cross Sectional Area or Diameter) cable to a smaller one.
Stu,
In my case I am only using single electrics so no fridges or anything like that will be coming from this feed, it's just to provide enough current for the trailer lights. Ideally I would like to run the feed straight from the battery distribution board under the bonet but am yet to find a way into the cabin.
Will spend some time at the wekeend with the multimeter on the fusebox and see what spare feeds I can find.
Andy
Still wouldn't want to run anything from the light socket to the towbar.
Certainly if you need a feed for a caravan fridge and battery charger you need a good feed with the correct grade of cable being used.
Hence my original question to try and find out how to take a feed through the bulkhead directly from the battery, there was a guide and some pics on here from a couple of years ago but unfortunately the pics are no longer there so I can tell exactly how to get the cable through :)
I did have a copy of the towbar install instructions but I can't seem to find them now. You could try asking a dealer if they have a spare set.
Dunno where mine takes the power from. It was fitted by the professionals before collection. Can have a poke about if its any use to you. Though mine is twin sockets rather than a thirteen pin arrangement.
Marcus and Stu, thanks for your guidance on this, Marcus, don't worry about having to dig around to see how your install was done just yet, I should have some more time available this weekend so will try a few things out to see where I can take the feed from, a good start was that I found my multimeter again (moved house last year and still finding things that have been trying to hide!)
