Pas & Electric Window Faults
Fabia 1.4 16v
Can Anyone Point Me In Right Direction
When I Viewed The Car The Pas Light Was On But Im 99% Sure When I Test Drove The Steering Was Fine. Left The Car With The Owner To Fix The Following, - The Passenger Electric Window Would Not Go Back Up. When I Collected The Car A Week Later The Pas Light Was No Longer On And The Passenger Window Was Fine, I Thought Great.
Since Getting Car Home I Am Finding That The Driver Window Has Fault, It Will Go Down But Only After Pressing The Switch Repeatedly. Also Occasionly When Unlocking The Car Both Windows Have Gone All The Way Down.
After Driving It For A Week The Pas Light Came Back On And The Steering Has Cone Extremeley Heavy.
Steering Fluid Is Fine - Took To A Local Mechanic Who Thinks It May Be An Electrical Fault, So Have Booked It Into An Electrical Auto Shop For Diagnostic Tomorrow.
Please Can Anyone Advise - Do You Think These Problems Could All Be Connected
Really Appreciate Any Advise As Scared Of Been Taken In Wrong Direction By Garage ££££
Try the search and I'm sure you'll quickly realise that the PAS fault is a common and often rather expensive problem.
As suggested previously looked at the PAS fault pages, but just wanted to know if anyone thought it was likely that these faults may be linked. Quite willing to get sensor changed but will having an electic dianostic highlight this requirement or is it likely that by having this done as suggested by mechanic it could be taking down the wrong road. Sorry but not mechanically minded
Ok, once you have your diagnostic printout then let us know what it says and we might be able to help.
