Poppin & Bangin
As title says am getting the full WRC rally effect when lifting off throttle, also mpg seems to be suffering. Only running at low boost at 277bhp most of time.
Have removed MAF and cleaned, also removed air filter and given it a good clean and re-oiled same.
Performance doesn't seem to have been affected but wallet getting palpitations with increased trips to the V Power alter:D
Any thoughts anyone?
Steve
Lamba sensor if performance is OK and fuel is crap would be my guess
Would this mean a trip to JBS or is it a diy job
Steve
Do you have VAG-Com that you could check and see if it shows anything up ?
I'm sure you could do the lambda sensor yourself, but for peace of mind, maybe throw it into JBS and get them to look over it.
The "WRC effect" is caused by over-fuelling (deliberately, as an anti-lag measure in their case).
Suggests a lambda failure to me.
Steve
Id take it there as it could be either the 1st or 2nd one and they will be able to easily find out rather than mess about underneath
Keep it :P
who doesn't want a wrc car? :D
Keep it :P
I had GEMS with Anti-lag on my Impreza.
Loved every minute of it. :D
Isn't this Q's old car. As I recall Jabba did the map, so why go to JBS. :confused:
Mind you I have been known to be wrong. :)
Probably another 100 mile journey?
Yup its a good 100 mile each way from our end
Cheers Guys
As Matt says Jabba not exactly local, just that I get the impression JBS is a very good outfit although Jabba have done all the work on the car. Only thing I don't want to do is have to fork out for new remap,if its just a sensor JBS is pretty local to me. Just want the best for the car and keep her running sweet.
Steve
Wouldn't think a remap is required at all so you're safe there i would imagine.
Either JBS or Jabba should be able to diagnose this fairly quickly for you. :)
Cheers my man will give them a bell and get her booked in:thumbup:
Steve
