Rear Park Sensors have packed up
As title says, rear sensors have packed up. recently has Nokia phone kit put in, which also failed after a couple of days (both went at same time) Phone installed co came out and found inline fuse they had put in for the phone power had blown.
Any obvious places to look in order to park sensors going again? Have check fuse, or at least I think its the right fuse going by the guide in side the fuse box cover, but it doesn't seem to totally match layout. Anyone know which fuse is the rear park fuse?
Funkycat
mine went to once and it turned out that the chime had gone faulty[30 euro].if you have access to vag com it'll show up on that.
the chime buzzer is located on octavia in passenger pillar ...not too diffficult a job.
although if other work was done on car ....it may have effected electrics....fuse locations are in handbook...you may have to look closer as there are different layouts...even on same car...
