Octavia Cruise Control Problems
Hi Sorry if I am posting in the wrong place but new to this.
I am on my 4th Octavia but this is the first with Cruise Control and it has a problem Sometimes it works okay until I use the indicator control to make a right turn then if on it cuts out or if I have used it but it is not on cruise then after I make a right turn it wont work again until I start a new jouney Any information on this would be useful
A fault code check would help but sounds like a faulty stalk to me.
I had also problems with cruise control. On service I had faults (sporadic error) from first service untill now (3rd one). And on the road some timer I cannot put the car on cruise until I turn off the engine and start again. You have to check the errors and see if you have to replace the module.
Thanks for the responce so far If anyone has had similar problems such as relacement of indicator stalk or module what sort of cost is involved as the vehicle is not under warranty
My car is under warranty so I do not know the costs
I have replied to your PM.
There was a batch of faulty parts fitted to early cars which fail indicating the symptoms of yours. Normally turning off the ignition and then back on will get it working again.
Hello, my cruise control has just packed up, only 11500 miles ,just still in warranty.skoda dealer diagnosed faulty on/off switch on indicator stalk being replaced tuesday under warrenty.
Hi Glad you can get yours replaced under warranty Just had mine sorted via VRSTU He sure knows his stuff
Nice to meet you this evening Brian. Sorry I couldn't stay to chat but as you know I had to get away.
Enjoy Weymouth.
