service and sun set glass
how many services do you have to have on a new car at what time like 6 month or is it miles and are the set services or do you pick which one you have and is it pos to get sun set glass after you get the car as the wife now likes it but it was to late to change order
10000 miles or 1 year which ever comes sooner. This is usually just an oil change unless it is annual where you have to have an inspection as well. If you do 10k in less than 6 months you can defer your annual inspection until 20k.
Your fuel filter and air filter are due at 40k but a lot of people prefer to change earlier. Cam belt is at 60k and brake fluid is every 2 years.
You can get the windows tinted aftermarket if you wish but it will cost you and you probably won't find your dealer can do this although there are plenty of 3rd parties who will
Beaten to it by Decron.
Re Sunset glass your dealer should be able to put you intouch with a tinting company, from the B pillar back should cost around £250.
Most dealers will sub let the window tinting, so you might as well go direct to them rather than paying the dealer mark up.
