Handbrake needs adjusting
Hi everyone
Handbrake needs adjusting on my 2004 54 Reg Skoda Fabia Vrs can anyone please help me with some advice on how to do this.
Many thanks in anticipation.
How many clicks is it on?
Mine is like 5 clicks on a very slight incline :|
Is that normal ?!
Yep, dont want any less than 5.
If you do need to adjust it take the "ashtray" out of the back of the centre console behind the handbrake and you shoud be able to get at the adjustment with a ring spanner
Not sure how many clicks it is on, at work at moment will look when I get home it is definately more than 5. Not holding car on inclines have to make sure the wife leaves it in gear.
Cheers the noo.
Cheers Skomaz if thats all it takes I will give it a try, is it really that simple.
Cheers.
Yep twas that easy on our estate so should be the same... took me about 5 minutes
Thanks Skomaz will post here when done and let you know how it went, won't be able to it till weekend though.
Cheers the noo.
Thanks Skomaz just as you said it took me 5 mins, seems to be holding well now if only life was that simple, many thanks and cheers the noo.
Willie
Glad you got it sorted!
