ebay or other cheap vag com cable recommendation needed-Moved
Hi lads,
Can anyone recommend me a cheap but still reasonably good USB vag com cable ?
I see a lot of cables on ebay but have no experience with them.
Any info greatfully appreciated
Igor:thumbup:
Edited by fatty5000
As far as I am aware and hopefully someone will confirm but the best cable is from Rosstech as it is the official cable. I believe if you use an ebay cable you lose some of the features with vag com. Hopefully someone can confirm as I am thinking about buying a cable as well.
If you have £100+ to spare get a proper Ross Tech cable, otherwise take your chances and get one for a tenner off fleabay. Obviously there is a risk with the cheap ones. I bought one and after some fiddling I got it to work but other people haven't.
Also without the proper cable or a software licence you can really only read and clear any error codes, you can't change anything. Depends on what you want it for.
Search the VAG/Diagnostics forum on here and all will be revealed...
Yes i've got one from hong kong, no problems at all.
I got my cable from eBay and after some fiddling with Com ports got it working OK but with my copy of Vag-Com being unregistered it's limited in what it will do.
Thanks you very much guys:thumbup:
Moved to a more appropriate area
Search for ebay seller alpha-bid
What he said :thumbup: My lead works great :D
Martziniuk, KINel, and Monkeychild: Can you please tell me WHICH eBay cables you bought? There are so many out there that I am clueless as to which will work with my 2005 Fabia 1.4 (Petrol); AND, please tell me which SOFTWARE you use? Is there Diagnostic software which comes with it? Or must you buy that separately? And lastly, aside from clearing error lights, what CHANGES CAN you make with these cables?? Thanks!
The ebay cables will only allow you to use the evaluation version of vagcom legally, you will be able to view fault codes but very little else.
And before anyone says otherwise we do-not condone the use of the pirated software on ebay and all references will be removed.
Looks exactly the same as mine :thumbup:
I bought mine from ebay and had no problems, and if you can get it working with the shareware version of VAG-COM you can buy a license from ross tech for US$99.
