Rear dampers 1.9 tdi estate
How easy is it to fit rear dampers to my fabia estate as one damper is leaking, should I replace both?
very easy to replace nd yes you should replace both
Thank you
Can you please give me a guide to replacing rear dampers
jack up,unbolt from bottom,remove rear arch liner,unbolt from up in the inner arch remove the topmount,swap to new damper and replace,it is a bit easyier if you remove the wheels too,but not strictly nessesary:thumbup:
this is on the hatch,but i am assuming the estate is the same
Don't jack up on the rear beam though!!
Probably worth ordering new bumps stops at the same time.
I really should order those, I've got the rear suspension still to fit :o
