Brake balance - VRS Mk1
What is the standard ? 50/50, 60/40 etc
Had my rear discs and pads changed recently and have covered say 500~ miles on them and have noticed some brake squeal under light braking.
After a burn I have also noticed the front discs are mega hot to touch whilst the rears are noticably less and touchable.
Is this the norm?
2003 Vrs btw ;)
Edited by Malc
Anyone?
The front brakes are doing a lot more work then the rears, so sounds normal to me?
If thats the norm then super cheers
The standard is 75/25 Isn't it?
Was going to drop it back in to be checked as I wasn't aware of ratio but it is breaking fine i'll give that a miss... gave it a bit of a run and the squeeling has pretty much dried up.
Obviously not caining it enough :D
Fronts should do the majority of the work, not sure on specific ratios though. The squeal is probably just the new pads/disk bedding in.
Fronts do most of the work, but how relevant is the bias ratio on a car with standard anti-lock?
FWIW, under really hard braking the weight distribution can move to something like 90/10 front/rear.
