Bought cheap manifold off ebay
hello
i have just bought this manifold of ebay..does this look like the right one to bolt onto the standard turbo??..were going to try fitting it on saturday if any one no,s could they let me no please..ive also got the decatpipe and an induction kit from the ebay as well..there cheap but ill let you no how they work :D
23931.attach
23932.attach
Edited by HaRRyBoNgO(uK)
:orb_no_no
Manifold will not fit and is cheap crap.
:orb_no_no
^^^^^^LOVE IT!^^^^^^:rofl:
(Mr Tact and Diplomacy at his best...)
Edited by jonnycatbiscuit
Do you no why it wont fit im going to try sending it back if it dos'nt so at least i can sound like i no what i mean when i tell them i would like my money back
Oh dear........... I think you will have fun, Manifold if it fits will not last long...downpipe looks ok what cel is it 100-200dpi? CAI.. others have issues with these, just make sure the filters not over oiled.
HTH
Phil
If its too good to be true it usually is, the unfortunate thing is people still buy it thus keeping the monkeys in business, It may fit, it may not one thing is for sure though and thats that it will last 5 minutes.
sorry dont no wot you mean by 100-200dpi but this is what the advert reads
This auction is for a BRAND NEW 100% Stainless Steel High Performance De Cat Down pipe
High performance Turbo Back Down Pipe is made to last longer and increase performance. All pipes are made with 100% stainless steel with silver chrome finish.
Spec and Features:
1 Piece design turbo back pipe, replaces factory catalytic converter to reach the best performance.
100% SUS-304 Stainless Steel with computerized mandrel-bends
2.5" piping
Comes with gaskets.
CNC machine flanges for strong solid support
TIG weld for strength and durability
3 stage polish shines like a mirror
Increase 10-16 horse power and torque
Straight thru design and bolt-on installation
Sensor Hole Inserts
FITS
Audi A3 1.8 150HP 98-02
VW Golf GTi 1.8 Turbo 99-04
VW Beetle 1.8 Turbo 99-04
SEAT Leon & Ibiza Cupra 20v Turbo
Seat Cordoba 20V Turbo
Skoda Octavia VRS 20V Turbo
Manifold is totally wrong as the exhaust and turbo will not fit onto the manifold.
Don't even think it will even bolt on unless you take the engine out and leave it out due to clearance on the bulkhead.
T3/4 fittment or something like that.
No cat then.......CEL light will be on and car will fail MOT emissions unless your lucky,,,how will you join the 2.5 inch pipe to the OE one?
yeah it looks that way..i was in 2 minds if i should buy it :(
ive been looking at the ebach springs how much did you lower yours?
37MM exactly!, I have them with Koni FSD's, still pretty comfortable but still very flat round corners! Do it!
hello
Oh yes, that will fit alright......
I suppose you don't have to use all 4 bolt holes as your turbo only has 3. Oh and the external wastegate will come in handy if you standard integral wastegate gives up.
Give it up.
Please in :orb_futur ask before you buy.
Hold on a sec Des, your whole car is not meant to fit together! :)
my friend said he can get me a down sizer made for it(but i was hopeing it would bolt onto the original one(but i guess not now) it says it has holes for sensor so wont that stop eml coming on
How much did you pay? Just out of interest.
Got that right, it's all trying to escape at the mo.
LOL As it always does!, the differance is everything in yours is to a high standard and expensive and it still breaks! So imagine what cheap tat will do Harry.
The sensors read whats going through it...you will have no monolith catalyst to reduce the emissions between the sensors, hence no reduction in emissions will result in cel light coming on.
Phil
Oh brother, comon for 130 what do you expect? A mistake i think bro, send it back if you can if not put it on a shelf above your computer to remind you of these errors.
pence.
But aren't decats used by a lot of members on this forum?
I have never heard of the cel light coming on.
Oh the cheaper stainless manifolds tend to crack from what i have heard.
Phil
so the decats no good as well then...i dont mind driving round with the eml on if its not causing any problems or is the pipe no good at all
If you dont mind the light being on then fine, i would buy a code reader though to make sure nothing else is going on, check regularly... by the way you will find the lambda probes will probably burn out as well.
Should have gone for a 100-200dpi cat pipe,
Phil
