Help please asap
i have installed some 6x9s today, on a stealth shelf managed to pick them both up for £10 off a m8 and the 6x9s are infinities which to be fair ant to bad,
So i dicided to take the power from the rear speakers for the mean time till i sort a sup and amp out, but in the fabia there are 4 wires running to each speaker, 2 look like power and 2 negative each clip having one of each, after studying 4 abit i decided to conect the speaker cable to both of these 'power' cables and the same with the 'negative' cables' making sure they dont touch each other and short out,
Everything works fine and its helped beef up the sound for now, BUT here is a big BUT, when i drive some where turn the engine off get out and lock the doors nothing happens the red light flashes in the keys but nothing, then say 2mins l8er try again it locks and will open and lock and open as usually, it seems the problem is only when i drive some where or start the engine, any clues
what i have done wrong????????
what i need to do to fix???????
cheers Richard
1
Edited by Richardsvrs
Look in the mobilephone guide on my fabia website and you'll find the correct pin outs for the radio, check your wiring with that.
