Bluetooth phonebook transfer problem
Hi..
I own an Octavia 2.0 Tdi and recently bought the bluetooth antenna so that i can use my phone ( O2 XDA ) in my car...
The connection worked ok, but i cannot retrieve the phonebook to the maxidot display.... It shows the message "please wait" and it stays like that indefinetely...
I've already installed an rSAP application that should permit access to SIM via bluetooth, but still doesn't work..
Any help ?
Do you have contacts on your handset and on the SIM?
I use a couple of HTC devices on mine (XDA's are HTC I think) without problem but I don't use an rSAP program and I have all the contacts on the phone.
I only have contacts on the phone memory... i tried to create a contact on the SIM, to check if the contact was retrieved.... but the same "please wait" message appears...
I've tried with another phone i have ( Sony Ericsson ) and it retrieves the contacts perfectly....
But as i normally use the PDA...
Did you try it without the rSAP software?
I've tried both with and without the rSAP software.... and it doesn't work....
Any more suggestions ?
How many contacts do you have? If you have 100's then it may be too much for the BT kit.
Which interface do you have?
Yes... i have many contacts....
I can make a test by deleting some contacts and check if it loads...
What do you mean by interface ?
Which module did you buy?
I didn't buy any specific module... I bought my car 2nd hand and it had already the skoda phone module.... i only had to buy the bluetooth antena and got the bluetooth activated in VAG com.....
It's not a separated one....
