any more modifications??
Modifications I here you say... Here goes:
Front and rear anti roll bars (doubled up rear ARB)
Front and rear strut braces
Bucket seats
Harnesses
Racing steering wheel
Stripped out interior
Custom dash (switches and push start)
Mk2 Favorit dashboard
Wind deflectors
Custom paintwork
Decals
Mudflaps
Cibie oscar spotlights
Fog lights
Air horns
14" alloy wheels
256mm front vented discs
Braided brake lines
Felicia rear beam
Felicia mpi fuel tank and pump
Mk1 Focus front coilovers
Mk3 Golf rear coilovers
Solid rubber engine/gearbox mounts
Fibreglass front wings
And the important engine stuff:
Ported and skimmed cylinder head
Bigger valves
Up-rated kent-cams valve springs
Estelle spring retainers and collets
Kent SK6 high-lift cam
Microsquirt ECU
Ford EDIS unit and coil pack
GSXR750 throttle bodies and custom intake manifold
Intake trumpets
Pipercross dome filter
Custom intake manifold
4-1 bodged exhaust manifold (needs replaced)
2" exhaust system (with cherry-bomb  :D )
Coolant sensor, intake air temp sensor, crank position sensor (36-1 toothed wheel)
Wideband lambda O2 sensor and air-fuel ratio gauge
Oil pressure sender and gauge
etc.
And also mapping it myself... however it needs a bit more work to get it tuned and running better!  :notme:
  • Like 2
