Which brake fluid?
I have just got round to buying a Gunson Eezibleed and will be ordering some fluid online. Any recommendations on a good quality brake fluid?
Also what size spanner do I need for the bleed nipple?
Ian
Edited by Lex Dysia
Another question
Dot 5.1 or Super Dot 4 (both essentially the same thing).
There's a sticky explaining all in the maintenance section i think.
Castrol Response would be my choice of fluid, if I could bloody find some!
Until then, I'm using Comma Dot 5.1
P.S. You can mix Dot 4, Super 4 and 5.1 without problems.
Hi.
I just buy Castrol SRF (don´t tried yet), because I want to change the brake line too…
Best regard´s
A.L.
how much fluid do you need to replace the fluid?
If your going to upgrade your brakes, or just need a really good brake fluid, try Silkolene ProRace 2000.
