sealing front doors
just finished sealing my front doors on a 04 vrs took some pics as i did it. so a very quick guide, havent done a guide before so apoligies if its a bit poor lol
pic 1
shows the position of all fixings you need to undo.
the top arm rest needs to be prised off and electric block disconected, then the second part of the trim slides towards the car and lifts out, 3x bolts to be undone
cover by door catch will prise out and 1x screw to undo
3x screws at bottom of door card to undo
light on bottom of door can be prised out
door card will then pull up and off, dont be scared to pull quite hard as takes some force to pull off
when removed reach behind and unclip the door catch wire, just a nipple conection, very similar to a bikes brake set up
when removing o/s door also need to disconect alarm light wire
pic 2
shows where all conections on back of door card are
you need to replace any broken clips, 22p each from dealer, each door has 6 clips on front, 7 on rears, make sure if reusing old clips that the rubbers are in place
pic 3
this just shows all components you have removed to be able to remove the door card
pic 4
shows where i have sealed from and to, i used quite a big bead, bout 5mm, and smoothed with a finger dipped in soapy water to make sure a good seal is achieved.
then put back together in reverse order
hope someone finds this helpful, took about 15mins per door, but i have had the cards off before so knew what to expect lol
Edited by heli195
OUTSTANDING my dear boy!!!!!!!!!
why thank you dear sir lol:D
Edited by heli195
Didn't think the front doors leaked or had any problems, thought just the back ones
can be both front and back, for the time it takes worth doing all 4 :)
When my rears leaked, the dealer did the front too in case. Apparently, the instructions they have say do all 4 regardless.
Very good guide.........:thumbup:
  • 8 months later...
Has the pictures disappeared?
