Skoda Superb 1,9 tDI ignition problem?
HI,
when i unlock my superb with a remote and try to start the engine it sometimes wont start, just wont start, than i have to lock the door again with the remote and than unlock for a few times and than it starts!!!Can this be a problem with the key?or the computer?
Please help me,thanks!
I think that might be a coding issue there :confused:
Can i re-code the key myself, i know that some manufactures have a scheme wit a key-like Citroen Xsara: i just opened the door with the key and hold the key in that position for 10 sec. Is there a scheme like that on Superb? Or do i have to go to a dealer...Thanks!
I'd go with dealer, unless you've got access to VAG-COM.
i have access to VAG-COM but how to do that?How do i recode the key???tnx:confused:
Umm... that I don't know, but I'm sure one of the resident tecchies has talked about recoding keys before.
I know it's a bit of a mission though, so perhaps my initial post should have read "I'd stick with a dealer unless you're really really good with VAG-COM" :)
To recode a key first you need the SKC code, you may have this - it will be on a plastic tag attached to your spare keys, it has a scratch off panel that contained the 4 digit PIN code.
You can then recode the immobilizer.
If you don't have the SKC code then it's a trip to the dealer for them to retrieve it (this will not be cheap, i have read they can charge over £100 to retrieve your SKC.
However, if the car starts with the key, i can't see that re coding the key will make a difference. If anything it is probably the receiver part of the immobilizer that is at fault.
I assume you don't have a huge bunch of keys attached to the ignition key? (that could be blocking the immobilizer)
:thumbup:
See? I told you someone knew what I was on about!
