My VRS wont start when it's cold outside!
Have had an intermittent problem with my Octavia VRS (52 plate). Totally dead when it gets cold, no sound, no start, no nothing - will start eventually but only when iginition is repeatedly turned. Any ideas as to what the problem might be? Garage has looked and failed to find problem. :(
It may be an intermittant starter solenoid. I assume that the dash lights come on as usual.
If you don't even get that, then I would suspect a relay.
Another vote for the solenoid, and get it sorted because the problem will only get a lot worse.
As a temporary measure, you maybe able to get it to start more readily by tapping on the side of the starter solenoid with a screwdriver handle when it will not start (assuming you can see the starter).
I have the same issue. No starter click - not a noise.
Dash lights are all on as usual, and as the OP said, it usually goes with the persuasion of a few choice words!
Thanks for the advice.
