Oil pressure gauge
Good morning all, i've got some guages to fit to my car to keep
an eye on the usual things (oil temp,oil pressure and boost). i was thinking about the oil pressure sensure the other day, do you think you can put the actual sensor on the oil return pipe from the turbo??? i was thinking this would help to monitor the oil pressure at the turbo just incase i get a blockage and end up with a dead turbo. do you think this would work?
I wouldn't interfere with the turbo oil lines mate, as long as the car is serviced at least every 10k (and driven sensibly) it should be fine.
I got my oil temp/pressure gauges hooked up to a sandwich plate which mounted where the oil filter locates, then in turn the filter locates on to this. Screwed in both senders and connected the wires and jobs a good'en.
You can't get these anymore I don't think, but something like this would be ideal if you can find one.
Steve:)
yeah i've had a look at those and found a motorsport company that can supply me with one. i work with vw and seen alot of cars that have had oil starvation at the turbo and fought it would be a good idea, but yeah your right that i could do more damage.
